bread board several surface mount ICs...
Any tips on how to bread board several surface mount ICs, standard
resitors, caps, etc and a (DIP) Basic Stamp?
Chris
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/web/.
Chris
You can use a standard breadboard if you mount your SMT parts to little
carrier boards that bring the pins out to a standard 0.1" spacing. You can
get some from Digi-Key (they are called "Surf Boards") or make up your own
or you can purchase mine [noparse];)[/noparse]
I offer some little adapter PCBs for SO-8, SO-16, SO-28 for cheap.
The adapters come as a small board containing several adapters. You have
to cut them apart with tin snips, solder on the SMT chip and add pins (I
use cut-off resistor leads). The boards are double sided with plated thru
holes and solder mask.
The SO-8 adapters take narrow (0.15") and wide (0.20") chips up to 8 pins.
The SO-16 adapters take narrow body (0.15") chips up to 16 pins.
The SO-28 adapters take wide body (0.3") chips up to 28 pins.
5 - SO-8 adapters $1.00 US
3 - SO-8, 3 - SO-16 $2.00 US
1 - SO-8, 2 - SO-28 $2.00 US
Add $1.00 US for shipping for up to 5 of the above cards.
Important note about the SO-8 adapters: the SMT part is mounted on the
UNDERSIDE of the adapter. There just isn't enough room to mount a 0.200"
wide SO-8 with gull wing leads between 0.3" DIP spaced leads.
Have a look at <http://www.trinity-electronics.com/customproducts.htm> and
contact me via PRIVATE email if you can use any of these.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
