BS2p Speed
What is the advertised instructions/second speed of the BS2p?
-Thanks
Martin Hebel
SelmaWare Solutions
StampPlot -- Data Acquisition and Control for Your Micro and Imagination
http://www.selmaware.com
-Thanks
Martin Hebel
SelmaWare Solutions
>-Thanks
>Martin Hebel
>SelmaWare Solutions
it claims to do 4k lines per second, but they make no mention how they came
up with that.. it would vary drasticaly if the lines did a lot of math or
not
i'd like to see some honest instruction speed measurements myself
pepsi@c...
very difficult to come up with an exact figure. Any, yes, mathematics
generally take longer. Since PBASIC is a specialized embedded language, it's
not possible to use "standardized" tests.
-- Jon Williams
-- Parallax
In a message dated 6/29/02 7:20:14 PM Central Daylight Time,
pepsi@c... writes:
> >-Thanks
> >Martin Hebel
> >SelmaWare Solutions
> not
> pepsi@c...
It's possible to make solid comparisons of the speed of individual
instructions or the speed for matching sequences of instructions on
the different stamps.
I have found the BS2p to be about 20% faster than the BS2sx. For
example, to execute the high 1 command, the BS2 takes about 140
microseconds, the BS2sx about 55 microseconds, and the BS2p about 40
microseconds. I have information on timing of individual
instructions posted at
http://www.emesystems.com/BS2speed.htm#timetables
although it is still sparse on the BS2p.
The BS2p uses a 20mhz clock, the same as the clock speed of the
original Stamp 2, and 2/5 the 50mhz clock speed of the BS2sx. But
the BS2p uses an Ubicom SX48 chip running in turbo mode, which
executes instructions up to 4 times faster than the old
"compatibility" mode. The net result is that, despite the slower
resonator, on the average the BS2p is about 20 to 25% faster than the
BS2sx. [noparse][[/noparse]The BS2pe (in beta test for low power operation) uses an
8mhz clock and is about 20 to 25% faster than the BS2 and the BS2e.]
-- regards,
Tracy Allen
mailto:tracy@e...
>Due to the structure of variable-length tokens and data in the Stamp, it's
>-- Jon Williams
>-- Parallax
>pepsi@c... writes:
> > >-Thanks
> > >Martin Hebel
> > >SelmaWare Solutions
> > not
> > pepsi@c...
>-- Jon Williams
>-- Parallax
i understand that you can't use a standard test to measure the speed, but
an attempt should be made to provide more meaningful data. how did
parallax come up with the figures they boast?
John Butera
pepsi@c...
