LED Light Level measurements
I have a project where I need to accurately measure the light levels
from a bank of red LED's. The requirements is to(using the reading)
adjust several groups to the same light levels for common camera
illumination levels.
I plan on taking a light level reading using ??? some type of
detector, pass it through a TLC548 8 bit serial A/d converter and
display the results on a serial LCD screen. Similar to gas detect
project in John Iovine's book.
My question is what type of
photo- sensor/detector/resistor/diode/transistor????? would be best
for reading red LED levels. if additional amplifiers are required
please help with that as well.
use with the Stamp. You can download the data sheet and lots of
application notes directly from Parallax:
http://www.parallaxinc.com/html_files/partners/taos.htm
Another approach is to use a photodiode directly with the RCtime
command. I used that in the earth measurements course:
http://www.emesys.com/EarthM/em4.pdf
"This lesson explains a photodiode as a linear light detector, and
uses it to explore the huge range of light in the environment. The
lesson gets into the math of sensor calibration. The data is logged
into memory, and means are provided to record several data points and
to play them back later."
The same LED could be used as the photodiode, to receive the specific
light wavelength emitted by your array.
-- best regards
Thomas Tracy Allen PhD
http://www.emesystems.com
mailto:tracy@e...
Any idea where I could find the Taos chip.
Newark, Digikey, Allied don't carry them (no search found on their
websites).
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YMA3MCgZfv4rmAg_HcdP33e_cr36aw969G4rrnjntjtCTJ7iD-R6zrxHfjZFWwpZuPwTdz74GF74keJBK9Ye]tracy@e...[/url
Sent: Friday, June 28, 2002 8:34 PM
Subject: Re: [noparse][[/noparse]basicstamps] LED Light Level measurements
The Taos light-to-frequency sensor chips are exceptionally easy to
-- best regards
mailto:tracy@e...
<http://www.future-active.com/>
You might have to buy 10.
>Thanks for the info.
>websites).
>From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qL2_9OyjtToYR6Qtow-ensylvkmNTRcqztSZIGZFmofcmXPpBZeGr0g2UfyLyqEncvS4PKT_o45N2A]tracy@e...[/url
> -- best regards
> mailto:tracy@e...
One thing to think about here is how you will collect the light from
the LEDs. If they are being used for illumination to take photos, you
want to locate the sensor at the camera's lens position, and as far
as possible collect light over the same solid angle that the lens is
imaging.
It may also be desirable to use a red filter over the sensor to help
mask out ambient light during the measurement. If you can obtain a
curve showing the wavelengths the target system is sensitive to, this
would help in selecting a filter.
Reg
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AB9R8ZFYr0dF7CSM8RLnQOfALiXemTCAn58iIoxFBrGw0ibO288wW45wAiqWEnAFiW76mkCz2pb_O5S0]tracy@e...[/url
Sent: Saturday, June 29, 2002 3:29 PM
Subject: RE: [noparse][[/noparse]basicstamps] LED Light Level measurements
Oh, I thought Parallax carried the TSL230, but I don't see it now. Try FAI:
>websites).
> -- best regards
> mailto:tracy@e...
