Measuring discharge length safely
Hi All,
I want to measure the length of a capacitor discharge pulse. The cap is
charged to 75V. What is the best method? I mean to physically hook it up.
Can I just use a resistor large enough to drop the voltage to what the Stamp
can handle? Klunky, but will it work?
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
Be sure to use a voltage divider made of 2 resistors, let's say 1K and 15K
in serie, from the + of the capacitor, 15K, 1K, - of the capacitor. You
measure accross the 1K resistor.
The voltage would be 75 x 1K /( 15K + 1K ) = 4.6875 V. This could be
acceptable.
Double check with a multimeter first !
Hope this helps...
Phil.
Sent: Thursday, June 27, 2002 2:50 PM
Subject: [noparse][[/noparse]basicstamps] Measuring discharge length safely
> Hi All,
Stamp
> Thanks,
> Jonathan
> www.madlabs.info
I was wondering if you could further elaborate on "I want to measure the length
of a capacitor discharge pulse". What exactly are you trying to figure out or
do? Find a value for a capacitor? If you know an emf value and a resistor you
can calculate how long it would take to discharge the capacitor. I don't
remember the formula off hand but i'm sure you can find it in a physics book. If
you were going to somehow interface 75 volts to a stamp I wouldn't take any
chances and do everything through an optoisolator.
-=Randy Knutson
Jonathan Peakall <jpeakall@m...> wrote: Hi All,
Jonathan
www.madlabs.info
from the same email address that you subscribed. Text in the Subject and Body of
Do You Yahoo!?
Sign-up for Video Highlights of 2002 FIFA World Cup
I have a coil gun (shoots metal projectiles). You can see it at
www.madlabs.info Calculating the discharge length of the capacitors is
difficult, because the inductance is changing as the projectile enters the
coil, and capacitor discharge rates with different cap arrays make a
difference and so on. I don't have a storage scope, so...
Just got some optoisolators today, and that is the plan. Any circuit
suggestions? I'm good at building, not so great at design.
Jonathan Peakall
> Jon:
length of a capacitor discharge pulse". What exactly are you trying to
figure out or do? Find a value for a capacitor? If you know an emf value and
a resistor you can calculate how long it would take to discharge the
capacitor. I don't remember the formula off hand but i'm sure you can find
it in a physics book. If you were going to somehow interface 75 volts to a
stamp I wouldn't take any chances and do everything through an optoisolator.
> -=Randy Knutson
Stamp
> Thanks,
> Jonathan
> www.madlabs.info
> Do You Yahoo!?
