AW: [basicstamps] Dying Stamp
Hi Scott,
I'm driving 2 sets of components:
1. a solenoid valve -- this is drived through an AC solid state
relay, triggered by one of the output pins, hooked into the stamp's
power supply ground.
You cannot drive the relay directly with a stamp-pin because it might take
more current that the stamp can deliver. You need a transistor to drive it.
Did you use a diode to prevent the relay to shoot back a current when turned
off?
2. a sparking mechanism -- this is also triggered by one of the
output pins, but through first a DC solid state relay and then a
standard coil relay. It has a 12V power supply.
So, the power supplies and circuits are electrically isolated as far
as I can tell.
Any ideas?
Scott
off?
as I can tell.
Any ideas?
Scott
