Atmel Dataflash
I'm tryin to use Atmel DataFlash with a BS2. I've followed Tracy's
code but I can not get it to work. The chip that I am using is a
AT45DB081B chip, not a AT 45D0. Has anybody had experience with these
chips?
Here's the code
temp = 138
'send data to buffer 1
'opcode $84, 15 dont care bits, 9 address bits
debug "sending", cr
low atcs
shiftout sdo,sck,1,[noparse][[/noparse]$84\8,0\15,0\9]
shiftout sdo,sck,1,[noparse][[/noparse]temp\8]
high atcs
temp = 0
pause 100
'read data back from buffer 1
'opcode $54, 15 dont care bits, 9 address bits, 8 dont care bits
low atcs
shiftout sdo,sck,1,[noparse][[/noparse]$54\8,0\15,0\9,0\8]
shiftin sdi,sck,2,[noparse][[/noparse]temp\8]
debug "got ", dec temp, cr
high atcs
I never get any valid data.
Any help appreciated.
Thanks again.
Simon
chips?
Here's the code
temp = 138
debug "sending", cr
low atcs
high atcs
temp = 0
pause 100
low atcs
high atcs
Thanks again.
Simon
Take a look at the hardware and software again.
Tracy's code and the code I sent to you does work.
David
Sent: Wednesday, June 26, 2002 9:31 PM
Subject: [noparse][[/noparse]basicstamps] Atmel Dataflash
> Hi,
> chips?
> Here's the code
> temp = 138
> debug "sending", cr
> low atcs
> high atcs
> temp = 0
> pause 100
> low atcs
> high atcs
> Thanks again.
> Simon
> Simon,
Thanks. The code below does work. The problem was that The RST and WP
pins do need to be pulled high. The datasheet specifies that they are
internally pulled high, but the chip did not work until I applied the
5v onto them.
Thanks again
> David
> From: "smorillas" <egroups@d...>
> To: <basicstamps@y...>
> > Hi,
these
> > chips?
> > Here's the code
> > temp = 138
> > debug "sending", cr
> > low atcs
> > high atcs
> > temp = 0
> > pause 100
> > low atcs
> > high atcs
> > Thanks again.
> > Simon
> > basicstamps-unsubscribe@y...
Subject and
