Re[2]: [basicstamps] Re: Serout - pin 16
Hi tracey!
Thanks for the help!!
I took me a while to find some time to do what you said.But right now I just
followed your instructions and it works like a breeze!
Thanks a lot!!
>>Hi!
>>"32780" on P0 works, but this means (according to the manual) "Open
>>Output", It doesn't have anything to do with normal or inverted
>>mode....
>>I think the first thing I will try is your option with the 2K
>>pull-down resistor... I will let you know how this works out
>>thanks a lot!
>Oh, right, open mode, not inverted! I didn't look at it carefully
>enough. That being true, the P16 serial output won't work without a
>bit of external hardware to reinvert the signal.
>The open bausdmode with 32780 from P0 to P15 will rest at a high
>level (given a pullup resistor), and it will go active low to send
>the start bit and other logical "0" bits.
>P16 always rests low. Here is a simple transistor open mode inverter circuit:
> N-mosfet 2N7000
midi
> P16 ---o--||---o
common
> `-/\/\--o
> 5k |
> Vss
> -- Tracy
from the same email address that you subscribed. Text in the Subject and Body
Thanks a lot!!
>>Hi!
>>mode....
>>thanks a lot!
> N-mosfet 2N7000
midi
> P16 ---o--||---o
common
> `-/\/\--o
> 5k |
> Vss
> -- Tracy
