reading lots of switches with 74148 priority encoder
Hello All,
I want to be to read 4 banks of 16 switches using the BS2. I know that
the 74148 encoder can read 8 switches, but I was wondering if there was
a 16 switch to 4 bit binary model. That way the 4 of them would fit on
the BS2's 16 pins.
I know there is a 74150 that allows you to select one of 16 pins and
read the state of that, but four of those consumes too 4 pins to many
for the bs2. Also, it would be more convenient to let the hardware do
the priority encoding.
Are there any solutions anyone can suggest?
Thanks in Advance,
-Paul Jordan
the BS2's 16 pins.
Thanks in Advance,
-Paul Jordan
>Reply-To: basicstamps@yahoogroups.com
>To: <basicstamps@yahoogroups.com>
>Subject: [noparse][[/noparse]basicstamps] reading lots of switches with 74148 priority encoder
>Date: Sat, 22 Jun 2002 10:23:57 -0700
>Hello All,
>the BS2's 16 pins.
>Thanks in Advance,
>-Paul Jordan
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
What about using a parallel to serial shift register/s?
Paul
_________________________________________________________________
Join the world’s largest e-mail service with MSN Hotmail.
http://www.hotmail.com
-Paul Jordan
From: P L [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gG39A6DadPP3qEcHEmgfEFaPFxrU5oQnW1tEQoLJS6kmFsZEVPEJg18-4fNFLe7Ct5_OcQZ0xGgJBP_Rp5cP]plugger02@h...[/url
Sent: Saturday, June 22, 2002 6:06 PM
Subject: Re: [noparse][[/noparse]basicstamps] reading lots of switches with 74148 priority
encoder
knowledgeable about them. Basically a paralell to serial shift register,
will take many inputs, and convert the states of all inputs to stream of
information on a single pin(also needs 2 timing pins). The SHIFTIN command
is designed to read the data stream from the shift registers, and place the
output into a variable. The most common shift registers are 8-bit, which
would allow 8 switches per device. You can also chain shift-registers
together to increase the effective ratio between output and input pins.
As I said I can't really help you all that much with them. I think there may
be application documetation on the parallax site. The stamp manual V1.9 has
some info shift registers, but the newest manual lacks this information. If
parallax is listening - why did the new PDF manual cut out all the
application info? I thought the old manuals with the extra application info
where much better.
Paul
You can use the SHIFTIN command to read
>From: "Paul Jordan" <automations@c...>
>Subject: RE: [noparse][[/noparse]basicstamps] reading lots of switches with 74148 priority
>encoder
>Date: Sat, 22 Jun 2002 18:13:20 -0700
>Sounds promising, can you elaborate?
>-Paul Jordan
>From: P L [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2Nac_CNcq0n3pNOgqKqD1KdYuO6qfm7sfDKrMbluRAXnAkncO6EVYfYUZaZM8xXQIv0J5qPbyDh4n4o2PVMUJg]plugger02@h...[/url
>encoder
Chat with friends online, try MSN Messenger: http://messenger.msn.com
output using the BS2, The 74LS165 are 8 bit devices that can be cascaded
for any number of inputs. The 74LS595 is your equivalent output. Both work
serial/paralell and I have had no problems using them.
Best of luck in your project
Eric
Sent: Saturday, June 22, 2002 10:01 PM
encoder
> I haven't had any experience with them myself and so I'm not all that
the
may
has
If
info
> where much better.
> Paul
> >encoder
> >-Paul Jordan
> >From: P L [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WSDxdU7WkyfgWWJ5RlXrnwdKid6H2s1Qly8Bj6XTXJH7mSgLNKeIyGfIfzw-Lks37ddqzZdSvA09d4EV]plugger02@h...[/url
> >encoder
inputs for each of the four devices is required for operation. You
could parallel four inputs from four devices and then use an enable pin
on each one to select it's value. This would require eight stamp input
pins. The problem with using shift registers is that variables on the
stamp are limited to 16 bits. A shift register chaining more bits than
this may have some software issues that might be difficult to deal
with. Certainly 4 - 16 bit shift registers would probably require less
wiring than 4 74150 priority encoders, but the shift registers would
lose the priority encoding, unless you could figure a way to do it in
software.
HTH,
Leroy
N8VRC
Paul Jordan wrote:
> Hello All,
> the BS2's 16 pins.
> Thanks in Advance,
> -Paul Jordan
