Socket for 28 pin SOIC
Does anyone have a part-number/supplier for a SOIC socket that I can
stuff onto a breadboard? There are a number of IC's (up to 28-pin SOIC)
I have lying around that I'd like to play with.
http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=309&M=PA-SOD-2808
-28
The adapter is about $70.00 US, but you still need the main socket which
goes for around $200.00.
http://www.logicalsys.com/datasht/28ss-otb.pdf
has a adapter it only sells for about $80.00
http://www.digikey.com/scripts/us/dksus.dll?Detail?Ref=95930&Row=46703
I find it a lot cheaper to simply add some small SOIC or TQFP prototype
board PCB layouts to a PCB layout
I have www.expresspcb.com make for me. Since you can cram a lot of stuff
onto a board it's more
cost effective.
From: Chris Levis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cAhdG81BHyS_hY18Eb2-VkTRgnAuO_HY7aRPHbSjviKaMSwAnaS5z3Vn_OVPSKTRHinsZk2H9zYugLW8W88RVoTyOg]stampslist@l...[/url
Sent: Friday, June 21, 2002 8:32 PM
Subject: [noparse][[/noparse]basicstamps] Socket for 28 pin SOIC
senior capstone project look much more professional.
> From: Earl Bollinger [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x86Qr-pmSz2hMg4O9quB4CGDIaBC6a6Ar6jGEloDqsEFynSqT69t4-ZBZBx8m62mANOvtppQ3jd-Oru9x5XT]earlwbollinger@a...[/url
> Posted At: Friday, June 21, 2002 11:34 PM
> Posted To: StampsList
> Conversation: [noparse][[/noparse]basicstamps] Socket for 28 pin SOIC
> Subject: RE: [noparse][[/noparse]basicstamps] Socket for 28 pin SOIC
> You aren't going to like it much,
> &M=PA-SOD-2808
> -28
> socket which goes for around $200.00.
board PCB layouts to a PCB layout I have www.expresspcb.com make for me.
Since you can cram a lot of stuff onto a board it's more cost effective.
From: Chris Levis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OTtkQfirGwk_TqjOMTMBmlJKrguCwNaYT_dWwmE-mDqWuAcC0mLn8RpFXlbun0doSHznEjprWo69jJTBgBTfuUMQ]stampslist@l...[/url
I etch my own adapters pretty easily. I use Eagle layout editor from
CadSoft. It is fairly easy to use and it is available as freeware
with some limitations. Once I have the layout I use a laser printer
with transfer paper from Dyna Art to transfer it to copper. I can get
10 mil traces with this paper using a household iron. There is
somewhat of a special touch to get it right but it is alot cheaper
than commercial adapters. I don't have any of the boards that I
etched handy for pictures to post here but I was able to make an
adapter for a Mictor connector with this process and a breakout board
for a 44 pin QFP for a PIC emulator. All boards so far have been 1
layer. I am planning on etching my own basic stamp 2P40 boards and
build a BS2P for less than $40. That includes buying all of the parts
necessary from Parallax and Digikey. The footprint will be alot
bigger but at least my pocketbook won't be lighter.
http://www.cadsoft.de/freeware.htm
www.dynaart.com/
Jason
--- In basicstamps@y..., "Chris Levis" <stampslist@l...> wrote:
> cb.com is a really cool site... New bookmark
> > From: Earl Bollinger [noparse][[/noparse]mailto:earlwbollinger@a...]
> > &M=PA-SOD-2808
> > -28
Ref=95930&Row=46703
prototype
for me.
effective.
> From: Chris Levis [noparse][[/noparse]mailto:stampslist@l...]
> To: basicstamps@y...
SOIC)
> Thanks
> basicstamps-unsubscribe@y...
Subject
Subject
I offer some little adapter PCBs for SO-8, SO-16, SO-28 for cheap.
The adapters come as a small board containing several adapters. You have
to cut them apart with tin snips, solder on the SMT chip and add pins (I
use cut-off resistor leads). The boards are double sided with plated thru
holes and solder mask.
The SO-8 adapters take narrow (0.15") and wide (0.20") chips up to 8 pins.
The SO-16 adapters take narrow body (0.15") chips up to 16 pins.
The SO-28 adapters take wide body (0.3") chips up to 28 pins.
5 - SO-8 adapters $1.00 US
3 - SO-8, 3 - SO-16 $2.00 US
1 - SO-8, 2 - SO-28 $2.00 US
1 - SO-16, 2 - SO-28 $2.00 US
Add $1.00 US for shipping for up to 5 of the above cards.
Important note about the SO-8 adapters: the SMT part is mounted on the
UNDERSIDE of the adapter. There just isn't enough room to mount a 0.200"
wide SO-8 with gull wing leads between 0.3" DIP spaced leads.
Have a look at
<http://www.trinity-electronics.com/public_html/customproducts.htm> and
contact me via PRIVATE email if you can use any of these.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Inc. If you have the current Digi-Key catalog, it's on page 821.
You have to solder the surface mount device to the Surfboard (a
tricky process), then you can plug it into a standard breadboard.
Unfortunately, the boards shown in the catalog only go up to 20 pins.
I found some good tips on soldering surface mount chips on the Yahoo
Groups board "Electronics 101"; you might search those messages.
SOIC)
> Thanks
