AW: AW: AW: AW: [basicstamps] Re: Tricky Random Question
Hey Tracy,
thanx for the neat little random-programs. I think the second one is
slightly above my horizon because the 'shifter' requires deeper
understanding of boolean operations. I know what an xor operation is in
principle but that is not enough to really see what you are doing there...
What I like most about the first program is that it is very simple but does
exactly what I wanted in the first place. The 'cheap trick' of picking them
up one by one, find a random second one and then just swap them was exactly
what I was looking for but I couldnot put my finger on it.
The elegant thing about it is that you get complete random in a defined time
for the price of the chance to replace some elements more than once which is
no price at all because it makes it even more random. To put it the other
way round: my own solution would have taken unpredictable time because I
would have to wait until random has 'found' every element of my list.
One more question: why couldn't I take a regular BS2 and use READ and WRITE?
Thanks again for your help and have a nice day,
Uli
Urspr
Uli
Urspr
My own first encounter with the "shifter" and its randomness was in a
biological context, but one very different from the one Dennis
described. In "chaos theory". Imagine an insect that is born, then
after a fixed number of days it lays eggs, and then, after a few more
days, more eggs, and so on until end of life. All those eggs went
back to the beginning of the "conveyer belt" of life. The total
number of insects on the "conveyer belt" built up and fluctuated
wildly, depending on the ages points for egg laying. There was also
a limited food supply that determined fecundity, so after a while the
population would build to large numbers and then crash. We also used
more realistic dynamic models where the timing was not fixed, and
those too could be "chaotic".
You could, but remember that the eeprom would wear out after some
large number of times, say one million. So if you only need to
execute this program 1000 times, it should not be a problem. There
are also tricks you can program in, to spread the wear out, by
changing the 90 bytes you use for the table from time to time.
>Uli
Good luck with the project. Is it part of a public exhibit or something?
Tracy
Also, it will be quite slow in comparison to using scratchpad RAM.
Each WRITE takes about 3 milliseconds, so doing that 180 times for
each shuffle would take over 0.5 second. Compared to about .05
second using PUT.
-- Tracy
