3.57MHz crystals
Hi. I have a project that requires decoding DTMF tones for decision
making. I'm using a BS2 and California Microdevices CM8880.
I see that the CM8880 requires a 3.5795MHz crystal to operate. As
luck would have it, I only have a 35MHz crystal.
My question is, what does a crystal do? I understand that it
vibrates, but what is its purpose and how are its oscillations
measured? Three years studying Computer Engineering, and I've never
had to use one. I'm looking for some background on it.
Thanks alot!
Thanks alot!
high-quality LCR (inductance/capacitance/resistor) circuit. So you can
think of it as a tuned circuit with a very high Q. Primarily, in this
world, we use them to set the frequency of an oscillator. However, in
other parts of the business they are also used a filter elements.
3.5795 is the "colorburst" frequency used in color television so there
is a high volume of these crystals produced and they are cheap.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: iamlevis2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f8jqeBULK1BXfA9gnLq2T4GPeAc9U6wdx1QIiN9EuJooEJi-iOHy6Rc_QG2BR5zYPbgUzESuJ7mKgkHaUl4Pmg]stampslist@l...[/url
> Sent: Wednesday, June 19, 2002 10:16 PM
> Subject: [noparse][[/noparse]basicstamps] 3.57MHz crystals
> Thanks alot!
> from the same email address that you subscribed. Text in the
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> You won't be able to make that substitution. A crystal is like a
very
can
this
in
there
> Al Williams
> AWC
> > From: iamlevis2 [noparse][[/noparse]mailto:stampslist@l...]
> > To: basicstamps@y...
decision
never
> > Thanks alot!
> > basicstamps-unsubscribe@y...
of quartz crystal (which is interesting all by itself -- how it is cut
determines many of its properties). A resonator is typically made from a
ceramic material. Resonators are more rugged and frequently less
expensive, but not as stable or accurate as a crystal.
You might find this article illuminating:
http://www.piclist.com/techref/microchip/osc.htm
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: iamlevis2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E6o7qYTW5tKcLiNCOYwsOex0xu1hlcUuro516BeRoYfxGvsjW4GLfFz5293lDqftupMMeZ6-FfR-ooL4HOfkfwsHg8bs]stampslist@l...[/url
> Sent: Thursday, June 20, 2002 12:19 AM
> Subject: [noparse][[/noparse]basicstamps] Re: 3.57MHz crystals
> Ok. And is a crystal the same as a resonator?
> very
> can
> this
> in
> there
> > Al Williams
> > AWC
> > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> decision
> operate. As
> never
> > > Thanks alot!
> television so there
> are cheap.
Radio Shack used to (And still should) stock that
particular crystal.
Chris
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
place of a crystal, if their frequencies match? I'm deciding between
a 3.58 ceramic resonator, or a 3.5795 crystal... It's for a DTMF
decoder IC (Specifically, the CM-8880)
Thanks for all the help...
> From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tOCgieyr5jLBb3EsVeYx02PB3S3ltLvCVg51ImXswFtpBCvfgoAnvpbOSOPn2QvujY5Iwo0HFya04w]alw@a...[/url
> Posted At: Thursday, June 20, 2002 8:37 AM
> Posted To: StampsList
> Conversation: [noparse][[/noparse]basicstamps] Re: 3.57MHz crystals
> Subject: RE: [noparse][[/noparse]basicstamps] Re: 3.57MHz crystals
> Well, they have the same function. A crystal is made by
> cutting a piece of quartz crystal (which is interesting all
> by itself -- how it is cut determines many of its
> properties). A resonator is typically made from a ceramic
> Al Williams
> AWC
> microcontroller http://www.al-williams.com/awce/pak1.htm
> > From: iamlevis2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=l9QuS-fcz5bUTtFbqENcKRCvVvWfOU3QVwaOV_Oao8qRc4uzH9-3mnR_NL1kBp001nGcrpveJJAzfzLi-sZMtEPFbRcg]stampslist@l...[/url
> > very
you
> > can
> > this
However,
> > in
elements.
> > there
> > > Al Williams
> > > AWC
> > decision
> > operate. As
oscillations
> > never
> > > > Thanks alot!
> the Subject
