Serout - pin 16
Hi, I just made a project where a BS2 should send a MIDI-code to a
sampler/keyboard.
the command in the code is this :
"serout 7, 32780, [noparse][[/noparse] $90, $25, $7F]" (here pin7 is the output-pin)
it works fine if I use PIN 0 .. PIN 15 as the output-pin to send
this command. The sampler/keyboard responds correctly to the MIDI
code it gets.
The problem is that all my PINs are used for other function and I
need to use the serial port. The manual says to use pin 16 in the
command. so when I use this piece of code :
"serout 16, 32780, [noparse][[/noparse] $90, $25, $7F]"
nothing happens!! the keyboard does not respond....
What is the difference between pin 16 and all the others?
PS I hook up the keyboard after the progam is downloaded into the
BS2.
- step1) download the program
- step2) disconnect the power from the BS2
- step3) disconnect the computer from the BS2
- step4) hook up the keyboard
- step5) power up the BS2
I hope someone can help me out!
Thanks!
sampler/keyboard.
code it gets.
BS2.
Thanks!
serout 16, 12, [noparse][[/noparse] $90, $25, $7F]
The P16 serial port hardware automatically inverts the signal. P0--P15 do not.
You have 31250 baud if that is a BS2. Right?
-- Tracy
>sampler/keyboard.
>code it gets.
>BS2.
>Thanks!
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
didn't work. then I saw that the parameter to invert everything was
wrong.
Instead of "serout 16, 12, [noparse][[/noparse] $90, $25, $7F]", I figured out it had
to be "serout 16, 32780, [noparse][[/noparse] $90, $25, $7F] to have 31250 baud
inverted.
But still it does not work....
Thanks anyway!
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> Try
-P15 do not.
> -- Tracy
> >sampler/keyboard.
> >code it gets.
> >BS2.
> >Thanks!
> > basicstamps-unsubscribe@y...
> MIDI-code to a
> sampler/keyboard.
> function and I
> pin 16 in the
According to the BS2 manual, regardless of the
baudmode setting, the data is inverted and driven
through the dedicated serial port (tpin=16). Could
this be your problem?
Chris
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
set it, "12" or "32780" does not make a difference. But the fact
that "32780" does work for you on P0 means that inverted is the
correct polarity.
Another take: Maybe there is a problem with the voltage levels or
speed. The P16 serial port steals power from the receive line, so if
you are not using that line, there is no power to steal and the
response is sluggish. Connect a resistor (~2 kohm) from your
transmit line (pin 1 on the IC) to ground. That should speed it up
and give it a solid low level.
-- Tracy
>Yes, the baudrate is 31250 baud. I tried your suggestion but it
>wrong.
>inverted.
>Thanks anyway!
"32780" on P0 works, but this means (according to the manual) "Open
Output", It doesn't have anything to do with normal or inverted
mode....
I think the first thing I will try is your option with the 2K
pull-down resistor... I will let you know how this works out
thanks a lot!
>mode....
>thanks a lot!
Oh, right, open mode, not inverted! I didn't look at it carefully
enough. That being true, the P16 serial output won't work without a
bit of external hardware to reinvert the signal.
The open bausdmode with 32780 from P0 to P15 will rest at a high
level (given a pullup resistor), and it will go active low to send
the start bit and other logical "0" bits.
P16 always rests low. Here is a simple transistor open mode inverter circuit:
N-mosfet 2N7000
midi
P16 ---o--||---o
common
`-/\/\--o
5k |
Vss
-- Tracy
