Multi BS2 network.
Can anyone offer advice on running a BS2 network? I've designed a
robot that uses a PDA as the master and a BS2 SX as a slave. I
wanted to add another Stamp and a CMUcam to make a serial network
that controls the robot. I have the software details in hand, I'm
just concerned about the hardware details. Can I just hook up the
serial lines of the stamps and have at it, or are there other
hardware details I need. I'm not finding much info on the net.
chris in napa
chris in napa
http://www.parallaxinc.com/html_files/downloads/download_documentation.htm
BASIC Stamp Manual, Version 2.0c, Page 289-290 for a graphic of one way to get
BS2's talking. Note the description states "I/O pin 0, Fpin, is pulled to
ground through a 10k resistor. This is to ensure that the sender sees a stop
signal (0 for inverted communications) when the receiver is being programmed."
Don
Sent: Saturday, June 15, 2002 7:01 PM
Subject: [noparse][[/noparse]basicstamps] Multi BS2 network.
> chris in napa
send and receive data but I still have the problem. The sender sent "Hello".
The receiver got all five letters but it was "Hdlln" instead.. This error is
constant. I am thinking about error from the last bit of each transmitted
byte.
Has anyone know what causes this error?
Roong
See the Stamp manual
get BS2's talking. Note the description states "I/O pin 0, Fpin, is pulled
to ground through a 10k resistor. This is to ensure that the sender sees a
stop signal (0 for inverted communications) when the receiver is being
programmed."
Don
> chris in napa
