IR Sensor Hookup — Parallax Forums
IR Sensor Hookup
edited 2002-06-16 05:24 in General Discussion
I have an IR object detector from and old kit that I put together a
while back and i want to add it to my new project. The sensor board
was made to hook up to a motor and control that motor so that when it
doesn't sense anything and when it senses something it reverses the
polarity to the motor and backs up. I was wondering how i could hook
this up to my stamp. I think i could just hook one of the motor wires
to a pin and then that will go high and low depending on whether it
detects something or not but i think that it wouldn't be a complete
circuit then because the circuit was made so that it goes into the
motor and comes out the other side so i was wondering if i needed to
ground the other motor wire or hook it up in some special way. Thanks
in advance for any info.
    edited 2002-06-16 03:37
    Greetings Duncan,
    Bruce Wynn here. Really could use a little more info on your IR sensor and
    its circuit layout. Normally an IR LED and an companion phototransistor are
    paired together to form a proximity or break the beam detector circuit. One
    lead of the IR LED and one lead of the Phototransistor will be tied to +5vdc.
    The other lead of the IR LED will require a current limiting resistor say
    about 220 ohms. The resistor will be grounded. This setup leaves the IR LED
    always on. The Phototransistor requires a resistor between +5 vdc and itself
    or between itself and ground. Resistor between + 5 vdc and itself produces a
    hi (+5 vdc) when the beam is broken. Without a wiring schematic on your
    sensor and its motor I cannot offer further info. Hope this helps.
    Bruce
    --- In basicstamps@y..., managerafs@a... wrote:
    > Greetings Duncan,
    sensor and
    phototransistor are
    circuit. One
    to +5vdc.
    resistor say
    the IR LED
    and itself
    produces a
    your
    > Bruce
