problems with SRF04 ultrasonic sensors
Hey, first off I am pretty new to this software. I am building a
self guided robot. I have a BS2 and am controling 4 rc motors with
the stamp. I am using four SRF04 sensors to guide it. One sensor
for each motor. Simple right? Well first using the pulsin pulsout
commands, I only got two of the four sensors to work. The third did
nothing, the fourth locked on high and kept its motor goin
constant. So then I switched the pulsin with rctime like it said in
the sensor booklet. That got the thrid one workin. Now I have
three sensors working without a problem. As soon as I hook up the
fourth it locks its motor on high. I have tried a bunch of things
like switching pins on the stamp and software, adding delays still
nothing. I have limited knowledge about this and was hoping someone
could help. Thanks
Ray
could help. Thanks
Ray
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] problems with SRF04 ultrasonic sensors
>Date: Sat, 15 Jun 2002 05:43:13 -0000
>could help. Thanks
>Ray
I obviously don't know the exact setup you're working on. But since you can
get the other sensors to work, how about taking one of the working sensors
out of the ciorcuit and swapping it with the sensor which doesn't work? That
way you can test to see if the sensor working ok, or if it's somewhere else
down the line. Also recheck all other circuitry and connections many times
over. If your like me you can sometimes make the silliest little obvious
mistakes and miss them on first inspection.
Paul Lugger
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
> >From: "jive_star" <jive_star_1999@y...>
> >Reply-To: basicstamps@y...
did
in
someone
> >could help. Thanks
> >Ray
you can
sensors
work? That
somewhere else
many times
obvious
> Paul Lugger
> Hey thanks for the help, but I am still having a problem. All the
sensors function when hooked up individually. The circuit has been
checked over. The system works perfect when 3 sensors are hooked
up. As soon as the fourth sensor is connected it screws up. It
sends a constant high to the motor. I am wondering if it might be a
timing issue. Here is the code. I hope someone can help me out, its
driving me crazy.
'{$STAMP BS2}
dr8 VAR DIR8
dr9 VAR DIR9
dr10 VAR DIR10
dr11 VAR DIR11
dr8=1
dr9=1
dr10=1
dr11=1
MotorA VAR OUT8
MotorB VAR OUT9
MotorC VAR OUT10
MotorD VAR OUT11
ADist var word
BDist var word
CDist var word
DDist var word
SonarAInit con 0
SonarAEcho con 1
SonarBInit con 2
SonarBEcho con 3
SonarCInit con 4
SonarCEcho con 5
SonarDInit con 6
SonarDEcho con 7
convfac con 74
MinDist con 6
CheckSonar:
OneSonar:
pulsout SonarAInit,5
output SonarAInit
rctime SonarAEcho,1,ADist
ADist=ADist/convfac
pause 10
TwoSonar:
pulsout SonarBInit,5
output SonarBInit
rctime SonarBEcho,1,BDist
BDist=BDist/convfac
pause 10
ThreeSonar:
pulsout SonarCInit,5
output SonarCInit
rctime SonarCEcho,1,CDist
CDist=CDist/convfac
pause 10
FourSonar:
pulsout SonarDInit,5
output SonarDInit
rctime SonarDEcho,1,DDist
DDist=DDist/convfac
pause 10
IF ADist<MinDist THEN BackOne
IF BDist<MinDist THEN BackTwo
IF CDist<MinDist THEN BackThree
IF DDist<MinDist THEN BackFour
BackOne:
MotorA=1
MotorB=0
MotorC=0
MotorD=0
GOTO CheckSonar
BackTwo:
MotorA=0
MotorB=1
MotorC=0
MotorD=0
GOTO CheckSonar
BackThree:
MotorA=0
MotorB=0
MotorC=1
MotorD=0
GOTO CheckSonar
BackFour:
MotorA=0
MotorB=0
MotorC=0
MotorD=1
GOTO CheckSonar
and the motors?
-kerry
>did
>in
>someone
>> >could help. Thanks
>> >Ray
>you can
>sensors
>work? That
>somewhere else
>many times
>obvious
>> Paul Lugger
>driving me crazy.
>'{$STAMP BS2}
>dr8 VAR DIR8
>dr9 VAR DIR9
>dr10 VAR DIR10
>dr11 VAR DIR11
>dr8=1
>dr9=1
>dr10=1
>dr11=1
>MotorA VAR OUT8
>MotorB VAR OUT9
>MotorC VAR OUT10
>MotorD VAR OUT11
>ADist var word
>BDist var word
>CDist var word
>DDist var word
>SonarAInit con 0
>SonarAEcho con 1
>SonarBInit con 2
>SonarBEcho con 3
>SonarCInit con 4
>SonarCEcho con 5
>SonarDInit con 6
>SonarDEcho con 7
>convfac con 74
>MinDist con 6
>CheckSonar:
>OneSonar:
> output SonarAInit
> ADist=ADist/convfac
> pause 10
>TwoSonar:
> output SonarBInit
> BDist=BDist/convfac
> pause 10
>ThreeSonar:
> output SonarCInit
> CDist=CDist/convfac
> pause 10
>FourSonar:
> output SonarDInit
> DDist=DDist/convfac
> pause 10
>BackOne:
> MotorA=1
> MotorB=0
> MotorC=0
> MotorD=0
> GOTO CheckSonar
>BackTwo:
> MotorA=0
> MotorB=1
> MotorC=0
> MotorD=0
> GOTO CheckSonar
>BackThree:
> MotorA=0
> MotorB=0
> MotorC=1
> MotorD=0
> GOTO CheckSonar
>BackFour:
> MotorA=0
> MotorB=0
> MotorC=0
> MotorD=1
> GOTO CheckSonar
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Very respectfully, your obedient servant.
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1132
using four mosfet drivers.
--- In basicstamps@y..., Kerry Barlow <admin@m...> wrote:
> A long shot here. Do you have enough amperage to run all of the 4
sensors
> and the motors?
> -kerry
a
with
sensor
pulsout
third
> >did
said
> >in
the
things
still
> >someone
> >> >could help. Thanks
> >> >Ray
since
> >you can
working
> >sensors
doesn't
> >work? That
> >somewhere else
> >many times
> >obvious
> >> Paul Lugger
the
been
a
its
> >driving me crazy.
> >'{$STAMP BS2}
> >dr8 VAR DIR8
> >dr9 VAR DIR9
> >dr10 VAR DIR10
> >dr11 VAR DIR11
> >dr8=1
> >dr9=1
> >dr10=1
> >dr11=1
> >MotorA VAR OUT8
> >MotorB VAR OUT9
> >MotorC VAR OUT10
> >MotorD VAR OUT11
> >ADist var word
> >BDist var word
> >CDist var word
> >DDist var word
> >SonarAInit con 0
> >SonarAEcho con 1
> >SonarBInit con 2
> >SonarBEcho con 3
> >SonarCInit con 4
> >SonarCEcho con 5
> >SonarDInit con 6
> >SonarDEcho con 7
> >convfac con 74
> >MinDist con 6
> >CheckSonar:
> >OneSonar:
> > output SonarAInit
> > ADist=ADist/convfac
> > pause 10
> >TwoSonar:
> > output SonarBInit
> > BDist=BDist/convfac
> > pause 10
> >ThreeSonar:
> > output SonarCInit
> > CDist=CDist/convfac
> > pause 10
> >FourSonar:
> > output SonarDInit
> > DDist=DDist/convfac
> > pause 10
> >BackOne:
> > MotorA=1
> > MotorB=0
> > MotorC=0
> > MotorD=0
> > GOTO CheckSonar
> >BackTwo:
> > MotorA=0
> > MotorB=1
> > MotorC=0
> > MotorD=0
> > GOTO CheckSonar
> >BackThree:
> > MotorA=0
> > MotorB=0
> > MotorC=1
> > MotorD=0
> > GOTO CheckSonar
> >BackFour:
> > MotorA=0
> > MotorB=0
> > MotorC=0
> > MotorD=1
> > GOTO CheckSonar
> > basicstamps-unsubscribe@y...
Subject and
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
> 607-775-1132
