Serial Port Programming Problem
Hi, I am begining to learn to write a Stamps 2 application. I wand
to send a short msg from my Computer to Basic Stamp2 though a
interface made by Visual Basic. I use MSComm1 object to initialize
a COM port. The Stamp 2 does simple job to return an acknowleedge to
the sender. They communicated through a straight through cable
(RS232 9 pin). Everytime I run the Stamps code through Stamp Editor
first on the COM 1 of the Computer, then I start run my application
on my Computer, I got a error msg " The Port is already open." If I
run the application first, then Stamp, same error. It sounds like
they both can not share the Port. I know threr is somewhere wrong in
my code. Would somebody fix the piece of code for me? I appreciate
what ever you give me a hits. (no Compile Problem)
Jenny Luo
This code is written by a book writer, Jan Axelson
Serial Port Complete, ISBN 096508192
Public Function fncInitializeComPort _
(BitRate As Long, PortNumber As Integer) As Boolean
'BitRate and PortNumber are passed to this routine.
'All other properties are set explicitly in the routine.
Dim ComSettings$
If MSComm1.PortOpen = True Then
MSComm1.PortOpen = False
End If
ComSettings = CStr(BitRate) & ",N,8,1"
MSComm1.CommPort = PortNumber
' bit rate, no parity, 8 data, and 1 stop bit.
MSComm1.Settings = ComSettings
'Set to 0 to read entire buffer on Input
MSComm1.InputLen = 0
MSComm1.InBufferSize = 256
'Input and output data are the contents of a byte array
'stored in a variant.
MSComm1.InputMode = comInputModeBinary
'MSComm does no handshaking.
MSComm1.Handshaking = comNone
MSComm1.OutBufferSize = 256
MSComm1.EOFEnable = False
'No OnComm event on received data.
MSComm1.RThreshold = 0
'No OnComm transmit event.
MSComm1.SThreshold = 0
fncInitializeComPort= True
End Function
Jenny Luo
Dim ComSettings$
End If
End Function
port open -- your Stamp editor. You can either run one or the other -- but
not both at once, or use a couple of pins and a MAX IC to make a second
serial port.
> Jenny Luo
this is what is preventing the VB script from running after you download to
the the stamp. Take out any 'Debug' statements and you should have no
problems. I run VB script all the time on the same serial port as the stamp
programming line (pin '16' on the stamp). It works as long as there are no
commands in the Stamp code that access the port.
Don
Sent: Thursday, June 13, 2002 2:53 PM
Subject: [noparse][[/noparse]basicstamps] Serial Port Programming Problem
> Jenny Luo
> Dim ComSettings$
> End If
> End Function
Don
> Jenny Luo
> Dim ComSettings$
> End If
> End Function
Don
> Jenny Luo
> Dim ComSettings$
> End If
> End Function
Some glitch in comm between Outlook Express and my ISP did it.
Don
Sent: Thursday, June 13, 2002 9:29 PM
Subject: Re: [noparse][[/noparse]basicstamps] Serial Port Programming Problem
> Does your Basic Stamp code have any 'Debug' statements in it? If so,
to
stamp
no
> Don
> From: "wlycory" <wlycory@y...>
> > Jenny Luo
> > Dim ComSettings$
> > End If
> > End Function
and
suggestions...... But I agree with Rodent that the stamp editor is what
has the port already open, For example:
your code contains this
End If
So there is where your prog is failing............my suggestion...make your
stamp program function with the vb interface only...........you only need
the stamp editor to "flash" the prog to the stamp.......from then on,
use your own interface. If you need to change the stamp prog, open the
stamp editor, change the code and close it before starting your vb
application.
hope that helps
Dave
Sent: Thursday, June 13, 2002 11:29 PM
to
stamp
no
> Don
> > Jenny Luo
> > Dim ComSettings$
> > End If
> > End Function
and
get another problem:
Everytime I send a meg to the Stamp and let Stamp
response with Acknowledge. The MSComm1.Input always
gets what is in the MSComm1.Output. It sounds like
they didn't talk each other. The PC actually talked
with its own Buffer. But MSComm1.InBufferCount really
got some number. If I disconnect the cable, PC got
nothing from its own Buffer. Please continue support
me while I am really need your hits. Thanks.
Jenny
--- Dave <samhell@s...> wrote:
> I am not familiar with vb script very well so I
> cannot comment on Don's
> End If
> application.
> hope that helps
> Dave
> From: "Don" <renegade.engineer@v...>
> Problem
> to
> stamp
> no
> > Don
> Problem
> application. I wand
> Stamp2 though a
> through cable
> run my application
> already open." If I
> Problem)
> > > Jenny Luo
> Axelson
> Boolean
> routine.
> routine.
> > > Dim ComSettings$
> > > End If
> bit.
> byte array
> > > End Function
> Text in the Subject
> and
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
