voltage measurement
Hi Stampers !!
Can somebody PLEASE help me !!
I have bought the BS1 and I want to send every watt hour an impulse to an
external counter.
The BS1 have to build the product between voltage, time and electric current
(W= U*I*t).
I can measure the elec. current over an low-ohm-resistor as a voltage.
Can anyone help me to create a circuitry and help me to find the right
PBasic commands?
Yours faithfully,
jens eckelman
-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-_-¯-
J e n s E c k e l m a n n
Geseniusweg 7
D-30625 Hannover
Germany
fax ¦ +49(0)121 2514850789
mp ¦ +49 (0)175 6945556
e-mail ¦ jens.eckelmann@g...
e-mail ¦ jens.eckelmann@w...
external counter.
(W= U*I*t).
PBasic commands?
Yours faithfully,
jens eckelman
Geseniusweg 7
D-30625 Hannover
Germany
high or low. Can it distinguish between 5vdc or 6vdc? Thanks, Chris
http://www.emesystems.com/BS2rct.htm#B_voltage
I have an analoge distance-mesurements-sensor which outputs a voltage
signal between 0.4 and 2.6 volt (80-10 cm.)
Is there an easy way to connect this snesor to the bascistamp 2 and
measure the voltage?
thanks harco
an A/D converter then feed the binary output into the stamp.
What you are looking for is an analog to digital converter (ADC or A/D). I
have used the LTC1298 for this purpose, and it works well. There are many
other A/D converters out there, and they all basically work the same way.
They compare your input voltage to a reference voltage and spit out a number
based on the difference between the voltages. Depending on what resolution
you need and what reference voltage you will use, anywhere from a 8 bit to a
12 bit A/D will probably work for you.
Jonathan
www.madlabs.info
Sent: Friday, January 10, 2003 8:20 AM
Subject: [noparse][[/noparse]basicstamps] voltage measurement
> Hai, I am realtively new to basicstamp-electronics
> thanks harco
and using an ADC chip.
the TLC1298 is 11 channel ?
for accuracy purposes, you may want to scale the signal from the
snesor so the full scale is 0-5 volts.
Also, if you chose a dual channel ADC, you could use a second amp to
scale the snesor output for some much higher range so you get higher
accuracy or at least higher sensitivity in a particular range.
For example if you sensor was set for 0 to 5 feet. and the ADC input
was 10 bit, the current voltage of 04. to 2.6 is a range of 2.2
volts. roughly that would input only 5 of the 10 bits. so the 5 foot
sensor range would wind up being about 10 foot as far as the snesor
goes. ie: 0-2.2 volts= the first 5 feet, 2.3-5 volts is the 'other' 5
feet, but unused.
By putting the snesor output thru an amp, you could set if for 0-5
volts for the full distance.
with a second ADC channel, you could then use another amp and pump
the signal up to the first foot was an output of 0-5 volts thereby
getting much higher resolution from the same snesor.
Any snesor would work, and a distance snesor or temperature snesor or
pressure snesor would work. (I am enjoying saying snesor)
Dave
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Harco,
A/D). I
are many
same way.
a number
resolution
bit to a
> Jonathan
> www.madlabs.info
> From: <harco@p...>
voltage
and
> > thanks harco
Subject and
Can I use Basic Stamp BS2p to measure battery votlage?
If yes, any AD/DA is needed for the circuit?
Thank you!!
>Dear all,
>Thank you!!
The answers to both your questions are YES and YES.
An ADC will be required.
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
> At 09:15 AM 5/4/04 +0000, ck1_chu wrote:
> >Dear all,
> >Thank you!!
How does it work?? Which command should be used.
I have no idea for this program.
