Tricky Random Question
Hi everyone,
I am working on a project and I have some random problem that might be easy
for you bit-wizards but seems too tricky for me:
I want to play 90 different files from a quadravox-soundchip. (it is a poem
spoken by a friend of mine). The aim is to play all 90 sounds in a random
order and next time in another order.
Always all 90 sounds shall be used. Aditionally no order should appear
twice, so that after a (very) long time every possible poem made out of the
90 words should have been played once.
How would I program this?
Thanx a lot, Uli
Thanx a lot, Uli
This is the "shuffled card deck" problem. I'd use a Stamp with scratch
pad memory like the BS2SX or BS2P. The reason is you need a bit to
represent the 90 "cards". That will take nearly 12 bytes. The process
is:
done:
count=0
gosub set_all_bits_to_one
wait:
gosub wait_for_user_input
top:
if count=90 then done
gosub generate_random_number
if bitarray[noparse][[/noparse]number]=0 then top ' already did that one
count=count+1
gosub do_sound_by_number
goto wait
Something like that? Of course, if the random number gets stuck so do
you. Another strategy would be to say:
gosub generate_random_number ' same as code above
loop:
if bitarray[noparse][[/noparse]number]=1 then exitloop
number=number+1
if number<90 then loop
number=0
goto loop
exitloop:
count=count+1 ' same as code above
This replaces the if bitarray test in the first snip.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G4UhN4aA70JTM4GmAWB5m9gcpQuOJDX6AcOKm1_zxZij_rb1BCbsXF5ygvsAxPGaNB60RgXzeDEK1utrCMV8kHqVXDZJ4G9vjJBa]ulibasic@r...[/url
> Sent: Wednesday, June 12, 2002 7:14 AM
> Subject: [noparse][[/noparse]basicstamps] Tricky Random Question
> Hi everyone,
> might be easy for you bit-wizards but seems too tricky for me:
> (it is a poem spoken by a friend of mine). The aim is to play
> all 90 sounds in a random order and next time in another
> order. Always all 90 sounds shall be used. Aditionally no
> order should appear twice, so that after a (very) long time
> every possible poem made out of the 90 words should have been
> played once.
> Thanx a lot, Uli
> from the same email address that you subscribed. Text in the
algorithmically generated. You can add some randomness by involving some
human interaction. At the beginning of your program you can have a loop that
waits on some human input while continuously calling the RANDOM function. If
you don't shake things up like this, you'll get the same results every time.
Then, you'll need 12 bytes (96 bits) to keep track of which file has been
played and a couple of routines (I would call them Mark and IsMarked) to
manage the bits. It really shouldn't be too tough -- about a pizza's worth
of programming time....
-- Jon Williams
-- Parallax
In a message dated 6/12/02 7:20:26 AM Central Daylight Time,
ulibasic@r... writes:
> Hi everyone,
(very) long time--90 factorial is about 15 followed by 137 zeros.
possible versions of the poem to make sure you haven't already played one.
Get your calculator out and see if you can figure out how many versions
there are -- 90x89x88x87... all the way to 2.
With this being said, you need to generate a list of 90 exclusive random
numbers -- this will determine what order to play the pieces in. One way to
do this is to generate a random number then verify it hasn't already been
used. The way to do this is generate an array of 90 single bit variables and
set each bit to a one as the number is used. Each time you generate a random
number between 1 and 90 you check the array, and if the number has been
used, get another.
easy
poem
the
If you are looking to see how many time it will take to get all of the
possible combinations it is;
1.485715964481761497309522733621e+138 the formula is n! on most calculators
or 90*89*...*1
this is a very large number, and I do not think it will ever be possible to do
with the Basic Stamp because of
it's size alone. I think you will get an overflow error before it is finished.
Have Fun !!
Dale Fleischmann
ulibasic wrote:
> Hi everyone,
> Thanx a lot, Uli
values)
This will keep track of what has already been played
Also a variable of how many more are still to be played
I am not much of a Basic stamp programmer, so here is a sub routine in a
standard VB type sub format
Private Sub PlayRandom()
Dim played(90,False) 'Just set the variable of 90 items to False (not been
played)
Var lefttogo=90 'Set the number of parts to be played
Randomize Timer 'Seed the random generator with time data
Do while lefttogo >0 'Loop until left to go = 0
myrandom = int(rnd(1)*90)) 'Get a random value 0>=random=<89
if played(myrandom) = False then 'If this bit has not bee played then...
[noparse][[/noparse]PLAY THE TRACK # myrandom] 'Play the track
Played(myrandom)=True 'Set Played to true for this track
lefttogo = lefttogo - 1 'Decrement the number of bits still to play
end if
Loop 'Loop back to Do statement
End Sub
I think this is correct
With tht nature of this code, the more 'bits' that have ben played, the
longer it will take to find the next one to play. Statistically, the loop
will have to loop 90 times to select the last bit to play. - I have
substituted program speed for simplicity and code size
I'm sure you undestand how this works, and how to port it to a basic stamp,
it is a fairly easy bit of code.
Sent: Thursday, June 13, 2002 12:20 PM
Subject: Re: [noparse][[/noparse]basicstamps] Tricky Random Question
> Hi Uli;
calculators or 90*89*...*1
to do with the Basic Stamp because of
finished.
> Have Fun !!
> Dale Fleischmann
> ulibasic wrote:
> > Hi everyone,
easy
poem
random
the
> > Thanx a lot, Uli
due to wanting real-time speech.
The drawback to keeping track of this real time and playing the words as
they are selected, rather than building an array of values from 1 to 90 and
playing the words off this list, is that as you start to use up all the
numbers the loop gets slower and slower, and the speech gets choppy.
> This is simple. Just set up an array of 90 boolean (True/False or 0/1
> values)
output values in an array, *THEN* playing the audio files realtime.
Regards
John
Sent: Thursday, June 13, 2002 12:43 PM
> I also suggested this method, but later realized there is a slight
drawback
and
> > values)
to mind the engineering slogan: a job that's not worth doing is not
worth doing well.
Dennis
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=F4i4TpEeeoTGUZmNjcRohiCRyNgETKr1rbGrne-0gxBpaiRevRLKZDg98nBsclJsGKzT6QZXriKcig]tracy@e...[/url
Sent: Wednesday, June 12, 2002 12:47 PM
>the 90 words should have been played once.
> Tracy's and Dale's comments concerning the number of combinations
bring
> worth doing well.
It occurs to me that alot of focus is being put on never repeating a
sequence of words...While that is ideal, this whole project would be
simplified by simply augmenting the random function, as someone
suggested, and picking the words one at a time until they are all
used...I seem to recall someone suggested setting bits for each
word? I don't recall which stamp was being used in the original
design, but is it possible to copy the pointers to the 90 words on
the chip into an array and randomize it? I've used this method in
QB4.5 (QuickBASIC) to randomize word lists in old word games.
Chris
At least *someone* thought my idea was worthy of more than a 1 second glance
Regards
John Burns
f i l e - i t @ x t r a . c o . n z
01000001 01100100 00100000 01000001 01110011 01110100 01110010 01100001
00100000 01110000 01100101 01110010 00100000 01000001 01110010 01100100
01110101 01100001
Sent: Friday, June 14, 2002 1:24 AM
Subject: [noparse][[/noparse]basicstamps] Re: Tricky Random Question
> bring
> > worth doing well.
> Chris
<file-it@i...> wrote:
> Thanks Chris,
Well John, it's the only useable solution that I can
see here...All the other methods will pretty much be
out of the range of the BS2's capabilities, while
being a little "overkill" for what is needed (IMHO).
Chris
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
I didn't mean by my comment to stifle creativity among stampers,
particularly on projects that combine poetry or art or music and clever
elctronics.
But from service on a number of (US) governmental advisory or review
committees, I'm frequently reminded that largely impossible projects
acquire funding and momentum before a watchdog group points out some
obvious flaws, as Tracy and Dale did on this otherwise admirable
project.
Dennis
From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3_4POioCX_YkM0Vh6jnIbEweMEB6p7PDooCy5WUPSQ58geO6gii0_fdO6S6AWvNhNq3ChQS5y8icZpsLdBsbsXkUpBF8_SKIhyrBLss]ulibasic@r...[/url
Sent: Thursday, June 13, 2002 7:45 AM
Subject: AW: [noparse][[/noparse]basicstamps] Re: Tricky Random Question
Hey all you people,
hey John, it is worth more than a glance, all of you helped me a lot,
really!!! I like the idea of finding the order first and then play the
poem because a pause of some seconds before each new version is good
anyways.
I think I didnt reflect on the impossibility of keeping track of all the
versions already played, maybe it is almost Goedel stuff: there can be
no system that is smaller than the number of possibillities that keeps
track of them... (maybe you can say that in better English... :-)
As far as Dennis is concerned: if this sentence is true I have spent all
my life doing things that are not worth doing them good...see for
yourself on www.u-winters.de
Thank you all, Uli
numbers and use this list to sequence the words. This is how cards are
shuffled in a card game.
glance
