Keyboard decoding
Does anybody here have any experience with decoding the data sent
from keyboards into ASCII format using the BS2SX? Thanks for any
help.
help.
codes and an Fbasic program to handle the caps and nums lock. The low
level timing of the clock and data lines is not covered. The real
problem with the keyboard interface, as far as the stamp is
concerned, is that the clock timing is generated by the keyboard.
Therefor, the stamp has to be fast enough to detect the edges of the
keyboard clock. Since the clock from the keyboard is usually about
30KHz, the BS2 is usually too slow to catch the data.
I think I remember seeing an article once about a fellow using an 8
bit shift register and some flip flops with a BS2 to decode the
keyboard interface, so that is a possibility also.
You could always just purchase the TICkit processor mentioned in the
article and use a 10 line program to convert the keyboard info into
ASCII. The TICkit could send the resulting info via RS232 to the
stamp.
http://www.protean-logic.com/applications/an039.pdf
--- In basicstamps@y..., "sethjaredjeromiejohnson" <sjohns10@h...>
> help.
at http://www.al-williams.com/awce/pak6.htm - you can order these direct
or through Parallax.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=05V0OBoIswgVgJHWR5LYR_NFGs7Mn2kGvZVBsDMU8TEruUHI6tGya2SdEhLw5-JnJ0t5k7takhtl_wva8aWkyqyNNLm-9C-HZbw-k6I]ulibasic@r...[/url
> Sent: Wednesday, June 12, 2002 2:36 AM
> Subject: AW: [noparse][[/noparse]basicstamps] Re: Keyboard decoding
> Hi Folks,
> you find all kinds of decoders at www.milinst.com
> They have Keyboard to rs232 as well as rs232 to PC (keyboard
> simulator).
> Regards, Uli
Urspr
now need to send the obtained keystrokes back to the PC. I'm working
on a product for my company that will take macros that are user
defined, via the PAk 6, and send them to the PC to automate
situations that can't be automated by software. I'm half way there in
that the obtaining data into the BS2 is working, but I need to send
it to the PC now. Do you have any clever suggestions on how to best
achieve this? I'm basically making a wedge that will act as a macro
sender without the need for a second PC to control the wedge. This is
an interesting project and could result in the need for numerious PAK
6 controllers as it will be used in automation within the validation
of the PC hardware we make.
Any help or advice on sending allready retrieved keystrokes is
appreciated!
I found someone has done the following and am investigating the
possibilities of using this circuit for the output since the input is
fine via the PAk 6 (http://www.al-williams.com/awce/pak6sim.htm):
o +5V
| 0.1uF / /
+----||---+ \ 2.2K \ 2.2K
| Gnd +
o Data
o CLOCK)
+ e | |
| Vdd | 10K |/ BC547 | +---o GND
| P0 |---/\/\/---|b (NPN) | |
| BS2-IC | |\ | ---
| | c | | Gnd
| | Gnd |
| | e _________/
| | 10K |/ BC547
| P1 |---/\/\/---|b (NPN)
| | c |
| | Gnd
| P2 |-
| P3 |-
| P4 |-
| P5 |-
| P6 |-
| P7 |-
| Gnd |
Gnd
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> If you need to read a PS/2 keyboard in a one chip solution, have a
look
direct
> Al Williams
> AWC
> > From: ulibasic [noparse][[/noparse]mailto:ulibasic@r...]
> > To: basicstamps@y...
> > Hi Folks,
> > simulator).
> > Regards, Uli
Urspr
just using a serial port to accept the data. You can use the Windows API
to force keystrokes into the system even though they didn't come from
the keyboard port. For an example, see http://www.wd5gnr.com/rfrem.htm
If you really need to hook up to the PS2 port, it may be possible to do
this with a Stamp although I personally have not tried it. The reason
the Stamp can't easily read the keyboard is that the keyboard generates
the clock and it is too fast for a standard BS2 to read. Even a faster
BS (like the P) has to monitor for data all the time which makes it
difficult to do anything else.
However, if you want to LOOK like a keyboard, then the Stamp generates
the clock and that should be a lot easier. In fact, Steve Parkis posted
some code awhile back to do this that IIRC worked with a BS2SX but not a
BS2:
http://groups.yahoo.com/group/basicstamps/message/20092
Good luck!
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: dajames519 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T0x-k7AKWc-qcsSLPZRWmYQDwW4_OXgOGd8hm-pTGMK-ly6Ljoqf0j1daFeQTZAEz24JDi0DLG_mTA]dajames519@y...[/url
> Sent: Friday, June 14, 2002 1:33 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Keyboard decoding
> The PAK 6 works great for obtaining input from the keyboard, but I
> appreciated!
o +5V
> | 0.1uF / /
> | Gnd +
o Data
o CLOCK)
+ e | |
> | BS2-IC | |\ | ---
> | | c | | Gnd
> | | Gnd |
> | | e _________/
> | | 10K |/ BC547
> | | c |
> | | Gnd
> | P2 |-
> | P3 |-
> | P4 |-
> | P5 |-
> | P6 |-
> | P7 |-
> | Gnd |
> Gnd
> look
> direct
> > Al Williams
> > AWC
> > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> > > Hi Folks,
> > > simulator).
> > > Regards, Uli
Urspr
to do this under multiple operating systems I cannot use the Windows
API and will attempt what Steve had done. Do the keyboard data and
clock lines need to be driven by a transistor or can the BS2 drive
them (to the PC) directly?
I'm thinking of attempting a method of 'hot-swapping' the keyboard
via a latch or something so the stamp can control thes signals only
when needed and the keyboard can be used normally when the stamp
doesn't have control. Any suggestions?
> Depends on what you want to do. First, if you control the PCs
consider
Windows API
from
to do
reason
generates
faster
generates
posted
not a
> BS2:
> Good luck!
> Al Williams
> AWC
> > From: dajames519 [noparse][[/noparse]mailto:dajames519@y...]
working
there in
send
best
macro
This is
PAK
validation
> > appreciated!
input is
o
+5V
> > | 0.1uF / /
> > | Gnd +
o
Data
o
CLOCK)
+ e | |
GND
> > | BS2-IC | |\ | ---
> > | | c | | Gnd
> > | | Gnd |
> > | | e _________/
> > | | 10K |/ BC547
> > | | c |
> > | | Gnd
> > | P2 |-
> > | P3 |-
> > | P4 |-
> > | P5 |-
> > | P6 |-
> > | P7 |-
> > | Gnd |
> > Gnd
have a
> > look
these
> > direct
> > > Al Williams
> > > AWC
> > > > Hi Folks,
> > > > simulator).
> > > > Regards, Uli
Urspr
high, so you'd simulate that by making the I/O pin an input.
Al Williams
AWC
> From: dajames519 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eYxcDqdZOaeVKE64TPihdY-NFfmrB56B2UKrdUeWq742N8C-HCpmU6nU5ya3c1THCmJeuDbIsdyoevVexg]dajames519@y...[/url
> Sent: Monday, June 17, 2002 1:04 AM
> Thanks for the advice on sending keystrokes to the PC. Since I need
> consider
> Windows API
> from
> to do
> reason
> generates
> faster
> generates
> posted
> not a
> > BS2: http://groups.yahoo.com/group/basicstamps/message/20092
> > Good luck!
> > Al Williams
> > AWC
> > * Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
> working
> there in
> send
> best
> macro
> This is
> PAK
> validation
> > > appreciated!
> input is
o
> +5V
> > > | 0.1uF / /
> > > | Gnd +
o
> Data
o
> CLOCK)
+ e | |
> GND
> > > | BS2-IC | |\ | ---
> > > | | c | | Gnd
> > > | | Gnd |
> > > | | e _________/
> > > | | 10K |/ BC547
> > > | | c |
> > > | | Gnd
> > > | P2 |-
> > > | P3 |-
> > > | P4 |-
> > > | P5 |-
> > > | P6 |-
> > > | P7 |-
> > > | Gnd |
> > > Gnd
> have a
> > > look
> these
> > > direct
> > > > Al Williams
> > > > AWC
> > > > > Hi Folks,
> > > > > you find all kinds of decoders at www.milinst.com They have
> > > > > Keyboard to rs232 as well as rs232 to PC (keyboard simulator).
> > > > > Regards, Uli
Urspr
used to download programs from the PC. Is there any possibility to decode a key
press from the PC by using this existing connection thus affecting the flow of
the program? (something like the input command used in other basic languages)
Thank you
__________________________________________________________
Sign-up for your own FREE Personalized E-mail at Mail.com
http://www.mail.com/?sr=signup
Save up to $160 by signing up for NetZero Platinum Internet service.
http://www.netzero.net/?refcd=N2P0602NEP8
This is very simple to do using the DEBUG window on the newer
stampw.exe versions. Use SERIN in your program to accept keystrokes
from the PC:
x VAR BYTE
SERIN 16,16468,[noparse][[/noparse]x]
This will cause your program to halt until a character is received
from the PC over the programming cable. Upon receipt, it will be
stored in the variable x. Then you can use BRANCH, IF or whatever
to do the right thing based on the byte received. Another pretty
nifty feature from the Parallax wizards.
You can even define macros to send a sequence of characters with a
single keyboard stroke.
With a bit more work, you can do the same thing with a terminal-like
program of choice that also communicates with your Stamp over the
programming cable.
Steve
Dimitris Tsabouras wrote:
> ...Is there any possibility to decode a key press from the PC by
> using this existing connection thus affecting the flow of the
> program?
