Geiger Counter / Horowitz Art of Electronics
Archiver
Thanks for the info. I was looking for something less
likely to repeat after seeing your earlier post.
(After I wrote this I saw ad with a reprint of the
Dilbert cartoon where a troll is introduced as the
budget group's "random number generator" and
repeatedly chants "NINE NINE NINE..."; "That's the
problem with randomness," says the troll who is
guiding Dilbert, "you can never be certain.")
As for ART OF ELECTRONICS by Horowitz and Hill, it
just came up twice in the PNP vs. NPN discussion, and
as Tom S pointed out that Bookpool.com has it for
$50.50. I just bought it at Borders this week with a
20% coupon they mailed me (sometimes it does pay to
get put on mailing lists), although apart from taxes
it would have been a few cents cheaper at Bookpool
using 3- or 4-day ground shipping. No one else seems
to discount it nearly so much (except used). If only
Bookpool carried all of my textbooks.
Regards
Bob Pence
--- "Dennis P. O'Leary" <doleary@h...> wrote:
> If your goal is random number generation, I'd
> recommend using software
> instead of the hardware complexity of a radioactive
> source, Geiger
> counter, and adjusting for 'dead time' of
> Poisson-distributed Geiger
> pulses. Repeating myself ...
> --- Sent to basicstamps on 4/27/02 ---
> A software Pseudo Random Binary Sequence (PRBS)
> generator of N bits can
> be programmed to produce a series of random numbers
> that repeats only
> after 2^N-1 numbers. It works by XORing certain
> bits and feeding back
> the results to a software shift register. The
> entire generator is a
> byte, word, or multiple words, for greater length,
> so this is an
> efficient program for a Stamp. I've used this
> approach on many machines
> to generate psuedorandom noise. For a really long
> sequence, 3 32-bit
> sequences can be used together to produce a
> nonrepeating sequence that
> repeats after 2^94 numbers. That's a long sequence.
> The universe is
> <less than> 2^49 seconds old.
> --- End of repeated section ---
> Information on PRBS generation is found in Horowitz
> & Hill, "The Art of
> Electronics", 2nd Ed, Cambridge U Press, New York,
> 1989, among other
> sources.
> Dennis
> (Former nuclear physics grad student before
> switching to biophysics
> decades ago.)
> From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TK7_D8A-ka-QnIcd34TIj3ylGpm2hD5hEujiRcTRvDD_U7x5VGEJu_LE4JZEY4WrirG-dlK8UurrujK9elEs9A]bobpence_2000@y...[/url
> Sent: Friday, June 07, 2002 8:50 AM
> Subject: [noparse][[/noparse]basicstamps] Geiger Counter for random
> numbers
> I've read in several places about using input from a
> Geiger Counter for random number generation.
> However,
> I haven't seen any Geiger Counters priced in the
> hobbyist range. (I do controls engineering for a
> living, but my company's customers would probably be
> concerned if there was a Geiger Counter on our
> equipment). Where can I get a cheap Geiger Counter
> (or
> a worse sense of timing)?
> Bob Pence
> __________________________________________________
> Do You Yahoo!?
> Yahoo! - Official partner of 2002 FIFA World Cup
> http://fifaworldcup.yahoo.com
> from the same email address that you subscribed.
> Text in the Subject
> and Body of the message will be ignored.
> Text in the Subject and Body of the message will be
> ignored.
Bob Pence
NOTE: This mail is sent using my wireless phone. Calling me at 1 (610) 563-6198
is preferred to a reply. If replying to this email address, please do not quote
the original message.
Do You Yahoo!?
Regards
Bob Pence
> source, Geiger
> that repeats only
> so this is an
> sequence, 3 32-bit
> The universe is
> & Hill, "The Art of
> 1989, among other
> sources.
> Dennis
> decades ago.)
> numbers
> However,
> (or
> Bob Pence
> Do You Yahoo!?
> Text in the Subject
> ignored.
Bob Pence
Do You Yahoo!?
Dilbert's troll provides a cool example from Shannon & Weaver's
Information Theory of a channel that transmits no information, in the
sense of p*log(p), because the message is always the same, and therefore
known.
Dennis
From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rwmNpnq-2JyN9GKEmxnDpcdWsRn_8I29YRrXiepLoJuAb5snffNxtDU0CI9dLJ-RRmhlSxC2tJH4DYfo1G1jVIaU]bobpence_2000@y...[/url
Sent: Saturday, June 08, 2002 1:39 PM
Subject: RE: [noparse][[/noparse]basicstamps] Geiger Counter / Horowitz Art of Electronics
Regards
Bob Pence
<deleted>
One other option is to pulse count from a noisy diode, like a shottky diode.
It will probably be cheaper than a geiger counter, but I think you'll have
to do a little research and experimentation. See the notes on pulse
stretching below.
Another lower-cost method would be to use a diode to demodulate random rf
signals from an antenna (basically a crystal set without the tuned cct) and
amplify the signals up to 5v. The pulses might be a bit too fast for the
stamp, so you might need a pre-scaler to divide the pulse train by say 1000.
Tony
Sent: Saturday, June 08, 2002 9:38 PM
> Regards
> Bob Pence
> > source, Geiger
> > that repeats only
> > so this is an
> > sequence, 3 32-bit
> > The universe is
> > & Hill, "The Art of
> > 1989, among other
> > sources.
> > Dennis
> > decades ago.)
> > From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WzwwghzOwu73HbFRy53v02buZn23_ZUqWuid-6xc-H3t2-WfG39uB1HAbrGLYy3CWu-NCrCrl4JbEXWqC6Sz]bobpence_2000@y...[/url
> > numbers
> > However,
> > (or
> > Bob Pence
> > Do You Yahoo!?
> > Text in the Subject
> > ignored.
> Regards,
> Bob Pence
563-6198 is preferred to a reply. If replying to this email address, please
do not quote the original message.
> Do You Yahoo!?
