driving 8 ohm, 100 watts speaker
Hello, I want to drive an 8 ohm, 100 watt speaker using freqout from the
stamp. Obviously a 386 op amp isn't going to provide enough power. Is
there a super high power version of a 386?
Go to www.national.com and check out the LM12C or the LM3886. The LM12C is an
opamp in a TO-3 package that can deliver 80 watts of sine wave power into a 4
ohm load. The LM3886 is a class ab amplifier that can deliver 65 watts of audio
into a 4 ohm load. Both of these IC's are configured like an opamp. They each
have two inputs an inverting and a noninverting depending on where you apply the
signal the gain is -RF/RIN or (RF/RIN+1). I can gurantee playing: "Mary had a
little lamb" with 80 watts RMS is going to be quite loud! ;-)
-Good Luck!
-=Randy Knutson
Do You Yahoo!?
Sign-up for Video Highlights of 2002 FIFA World Cup
drive my 80W 10 inch speakers OK at fairly loud volume. Remember, the human
ear is logirythmic (that's why volume control Pots are logirythmic), so in
order to get twice the power, you would to increase the power 10 tens to a
20W amplifier, like the LM1875. Both chips are easy to use, however, the
LM1875 needs + and - 30V rails, whereas the LM380N will work from about 6V
to 18V single rail. There is also the LM12, 150W Power Op Amp, which I
briefly played with once...
Cheers,
Ben, Wellington, New Zealand.
> From: raoul vaneigem <raoul@c...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Sat, 08 Jun 2002 10:25:39 -0700
> Subject: [noparse][[/noparse]basicstamps] driving 8 ohm, 100 watts speaker
> of the message will be ignored.
I meant to say: "...so in order to get twice the volume, you would need to
increase the power 10 times..."
> From: Ben Lennard <postmaster@s...>
> Date: Sun, 09 Jun 2002 14:57:13 +1200
> To: <basicstamps@yahoogroups.com>
> Subject: Re: [noparse][[/noparse]basicstamps] driving 8 ohm, 100 watts speaker
> Speakers are very inefficent. I found that an LM380N 2 watt power amp will
> order to get twice the power, you would to increase the power 10 tens to a 20W
> amplifier, like the LM1875. Both chips are easy to use, however, the LM1875
> needs + and - 30V rails, whereas the LM380N will work from about 6V to 18V
> single rail. There is also the LM12, 150W Power Op Amp, which I briefly
> played with once...
> Cheers,
>> Body
