Semiconductors (???????)
Another semiconductor question: how do the drain, source, and gate on a
MOSFET equate to the base, collector, and emitter on a standard transistor?
Don
> Tie the gate to the stamp pin, no resistor is required as the mosfet's
gate
> load is less than a microamp at dc and only a small capacitive load, if
you
> prefer you could use a resistor anything from 470 ohms through 1 meg will
> do. (I personally use a 10K if anything, because I accidentally ordered
ten
> thousand 10,000 ohm resistors).
> Tie the drain lead to the relay coil, and put a diode across the coil
> (reverse biased) to limit inductive kickback.
Don
gate
you
ten
On an N-channel MOSFET which is similar to an NPN transistor:
COLLECTOR = DRAIN
BASE = GATE
EMITTER = SOURCE
Don <renegade.engineer@v...> wrote: Another semiconductor question: how
Don
gate
you
ten
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do You Yahoo!?
Sign-up for Video Highlights of 2002 FIFA World Cup
They are not equal, they don't equate!
At the silicon level a MOSFET's source and drain can be interchanged
equally because they both sit in the same NWELL or PWELL and there
are no physical differences between them. In the real world sometimes
you cannot reverse Source and Drain because often there is a Diode
across them due to some manufacturing processes creating a PN junction or
by design, sometimes a diode is placed on purpose to help prevent silicon
latch-up.
NMOS:
P SSS GGG DDD P
PPPPPPPPPPPPPPP
PMOS:
P N SSS GGG DDD N P
P NNNNNNNNNNNNNNN P
PPPPPPPPPPPPPPPPPPP
Bipolar transistor's on the other hand can not exchange emitter and collector
because they sit in different wells with each transistor component creating
a pseudo-well if you will. i.e. the Emitter sits in the Base well while the
Emitter and Base both sit in the Collector Well. The Well in which the
Collector sits in determines the type of transistor NPN or PNP.
NPN:
P CCC BBB EEE BBB CCC P
P CCC BBBBBBBBBBB CCC P
P CCCCCCCCCCCCCCCCCCC P
PPPPPPPPPPPPPPPPPPPPPPP
PNP:
P N CCC BBB EEE BBB CCC N P
P N CCC BBBBBBBBBBB CCC N P
P N CCCCCCCCCCCCCCCCCCC N P
P NNNNNNNNNNNNNNNNNNNNNNN P
PPPPPPPPPPPPPPPPPPPPPPPPPPP
Key:
N - N+WELL
P - P+WELL (sub)
S - Source/Drain
D - Drain/Source
>Don
>gate
>you
>ten
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
Don
Sent: Thursday, June 06, 2002 11:38 AM
Subject: Re: [noparse][[/noparse]basicstamps] Semiconductors (???????)
> Don:
> COLLECTOR = DRAIN
> BASE = GATE
> EMITTER = SOURCE
transistor?
> Don
> gate
> you
will
> ten
> Do You Yahoo!?
