Semiconductor PNs and sources
Archiver
I've been looking for parts referred to me in a previous thread. I can
find the semicondutors listed under '2NXXXX' type numbers, but I can't
locate any listed under the 'BCXXX' type numbers. I've tried DigiKey,
Jameco, and Radio Shack. Does anyone know who makes these 'BCXXX' PNs
and/or know of an online source?
Don
Sent: Tuesday, June 04, 2002 8:51 AM
Subject: RE: [noparse][[/noparse]basicstamps] Grounding Issue
> BC337, BC107, 2N3904, BC107,8,9 all NPN devices with HFE >50. Put a 4.7K
> OHM resistor in series with base connection (will limit I drawn from
> chip to approx 1mA), and don't forget a back EMF diode across the relay
> coil (1N4000 or any of the 1N4*** series will do).
> ROB
Don
> ROB
Sorry the BCxxx series of transistors is causing you a problem. They are
just a generic general purpose device, used widely in the UK and Europe.
It appears that they're not so widely used in the U.S.
The devices you want will generally conform to the following.
HFE >50, VCE >20 volts DC, IC >100mA ft > 100KHZ.
Any general purpose switching transistor will do. MPSA43 seems
good (Radio Shack). Radio Shack Cat. #: 276-1617 15 NPN devices for
$2.49 good as well. Hope this helps.
Rob
From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FxOYcI0-MHlkG9VL67mKMeK1_-GGWY6iYsOY5YI0zh5BUjB9D9euZMOlM9uqcY73U_Yek7hVdatz3JLuzoVEmXIKdyBhf3w]renegade.engineer@v...[/url
Sent: 06 June 2002 17:13
Subject: [noparse][[/noparse]basicstamps] Semiconductor PNs and sources
can
Don
4.7K
relay
> ROB
Your use of Yahoo! Groups is subject to
Don
Sent: Thursday, June 06, 2002 11:24 AM
Subject: RE: [noparse][[/noparse]basicstamps] Semiconductor PNs and sources
> Hi Don,
> Rob
> From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=A2VbhFsOEVHC_DPnew1aHl5uHSH8LN0u4vE5deIx2qSLLG_c7CdWzGHA68y9bmU2xGdGwR9OV4_x6f_FcafTkmW5HnRlqgrB]renegade.engineer@v...[/url
> can
> Thanks
> Don
> From: "Rob" <robbed666@b...>
> 4.7K
> relay
> > ROB
