Digest Number 1245
Hi there,
I was just trying to find out what actually stamp processors are,what are their
advantages and how they could be used in small control applications.So, please
could anyone send me the materials on that????
basicstamps@yahoogroups.com wrote: To UNSUBSCRIBE, just send mail to:
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
There are 25 messages in this issue.
Topics in this digest:
1. DS2406/2407
2. BSII DOS Editor
3. Re: BSII DOS Editor
4. Apology to Leroy...
5. Re: BSII DOS Editor
6. Grounding Issue
7. Problems with the L298 Motor Driver Kit ?
8. Stamp Cloning....
9. Re: Problems with the L298 Motor Driver Kit ?
10. Re: Problems with the L298 Motor Driver Kit ?
11. Re: DS2406/2407
12. Re: BSII DOS Editor
13. Can someone help with a counter for an input?
14. electron movement?
15. Re: Problems with the L298 Motor Driver Kit ?
16. Re: electron movement?
17.
18. Re: electron movement?
19. Re:
20. Re: Problems with the L298 Motor Driver Kit ?
21. RE:
22. Re: GPS Module
23. Re: Grounding Issue
24. Re: electron movement?
25. little step-u
________________________________________________________________________
Message: 1
Date: Mon, 3 Jun 2002 14:21:26 +0200
Subject: DS2406/2407
Greetings!
Is there anyone else who has any experience using these 1-wire switches
together with a BS2p?
I can read the ROM and matchROM, but no matter what I do, I can't seem to
get it to switch...
Trygve
Message: 2
Date: Mon, 03 Jun 2002 15:53:59 -0000
Subject: BSII DOS Editor
Is there a version of this program that will work on a monochrome
LCD? I can't see the cursor on my old laptop . . . thanks.
Message: 3
Date: Mon, 03 Jun 2002 12:04:42 -0400
Subject: Re: BSII DOS Editor
Start it with the /M switch as below...
STAMP2 /M
Jim H
Message: 4
Date: Mon, 3 Jun 2002 12:07:03 -0400
Subject: Apology to Leroy...
This is an apology to Leroy. I have been running on limited sleep
recently, and mistakenly referred to a suggestion that someone else gave as
coming from Leroy.
Just to clarify where it originally came from...near the end of that thread
(after Dale quoted a hunk of the manual's explanation of the function of
POT/RCTIME) he ended with:
I am not sure if the POT instruction is what you are looking for to solve
your problem, but try this first add the
LED between the resistor and the capacitor and see if this solves your
problem.
Have Fun !!
Dale Fleischmann
I don't think he realized the RC network was not intended to DIRECTLY
influence the flashing of the LED (that's where the "no electronic sense"
comment came from), but rather provide a "factor" so that the code could
handle the flash rate.
I'm going to shut up now and maybe catch 2 3/4 winks. Or maybe it was just
my evil and slightly stupid twin that stepped in....yeah....that's the
ticket...
The information transmitted is intended only for the person
or entity to which it is addressed and may contain confidential
and/or privileged material. If you are not the intended recipient
of this message you are hereby notified that any use, review,
retransmission, dissemination, distribution, reproduction or any
action taken in reliance upon this message is prohibited. If you
received this in error, please contact the sender and delete the
material from any computer. Any views expressed in this message
are those of the individual sender and may not necessarily reflect
the views of the company.
Message: 5
Date: Mon, 03 Jun 2002 16:54:34 -0000
Thank you.
> STAMP2 /M
> Jim H
Message: 6
Date: Mon, 3 Jun 2002 10:02:56 -0700
Subject: Grounding Issue
I want to try again since there were no responses before. Hopefully one
of the electronics Gurus out there can give some ideas! Please see my
question below. I welcome any suggestions!
Don
Sent: Sunday, June 02, 2002 9:23 AM
Subject: [noparse][[/noparse]basicstamps] Grounding Issue
> Hi folks!
> I'm using a BS2 on a Super Carrier to control a BS1 Rev.D, which in
> turn controls a couple of relays that turn LED's on and off. All of
> the controlled circuitry (relays, LEDs, associated wiring) is on a
> separate breadboard because the Rev.D's prototype area is too small.
> The BS1-to-breadboard connections are:
> 1.BS1 5VDC to breadboard common power strip, 2. four(4) stamp pins
> to relay set and reset pins for switching signals, and 3.BS1 ground
> pin to breadboard common ground strip.
> Another pin on the BS1 is connected to a pin on the BS2 for serial
> control signals, and the BS1 ground is also connected to the BS2 VSS.
> Now the strange part; the system only works properly when the BS1-
> to-breadboard ground line is DISCONNECTED. When I hook it up, I get
> inconsistently bad results.
> You may wonder why I ask, when I know how to make it work!?!
> Because I want to get an OEM BS1 and make a custom PCB to put all but
> the BS2 on a single module. This means that the previous BS1-to-
> breadboard ground, which seems to cause the trouble, will now be
> permanent. If I can't find out why it's messing up under this
> condition, I'm toast. By the way, the breadboard ground strip is NOT
> connected to any other external ground.
> Could it have anything to do with the fact that, when the BS1-to-
> breadboard ground is hooked up, it is also directly connected to the
> BS2 VSS? I can't disconnect the BS1-ground-to-BS2-VSS line, as then
> I lose all serial comm for control signals.
> I hope this is clear enough to understand the problem.
> Any ideas?
> Thanks
> Don
Message: 7
Date: Mon, 03 Jun 2002 17:07:23 -0000
Subject: Problems with the L298 Motor Driver Kit ?
I was looking for solutions to drive 2 DC motors that can be
controlled with a basic stamp 2. I bought 2 - L298 Motor Driver Kit
from HWV. It is working fine for 1 or 2 hours(i am controlling little
robots with to wheels) and then the chip burns... My 12vdc motors do
not run for more then 1 Amp...
I tried many things it always end the same way !!
Do anyone had the same problem? any solutions or tips?
Do anyone have another solutions (with explicit diagrams!) to drive
two DC motors with a basic stamp? I need something that can handle
runing for 6 to 8 hours continuously going back and forth...
Artist stuff !!! [noparse]:)[/noparse]
Merci
TANKS
St
1. DS2406/2407
2. BSII DOS Editor
6. Grounding Issue
11. Re: DS2406/2407
17.
19. Re:
21. RE:
22. Re: GPS Module
25. little step-u
Message: 1
Greetings!
get it to switch...
Trygve
Message: 2
Message: 3
STAMP2 /M
Jim H
Message: 4
coming from Leroy.
problem.
Have Fun !!
Dale Fleischmann
ticket...
Message: 5
Thank you.
> STAMP2 /M
> Jim H
Message: 6
Don
> Hi folks!
> Any ideas?
> Thanks
> Don
Message: 7
Merci
TANKS
St
>their advantages and how they could be used in small control
>applications.So, please could anyone send me the materials on that????
http://www.parallaxinc.com
PLEASE don't repost the whole digest when posting a response to it.
Jim H
Had you thought of deleting all the digest content that you quoted along
with your question? Or do you think that it would have been better to have
just started a new thread?
Regards, Derryck
