SV: [basicstamps] Program slots
Greetings!
Also, the BS2 series allocate RAM to variables on a 'biggest first' base, so
it allocates Word types first, then Byte (and Byte arrays) before Nibble and
finally Bit variables.
Therefore, if you use the RAM to pass information back and forth, make
certain that you declare all common variables First, and make the Word
types. (You can alias the .HighByte/.LowByte/.Nibble parts afterwards)
If you're using EEPROM area to store data, don't forget to use the STORE
command to point to the correct page. (I think it defaults to the page
you're jumping to if you use the RUN command. I make it a habit to run this
command as one of the first on every page :-)
Trygve
http://home.c2i.net/trygveh/english/
Opprinnelig melding
Fra: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1XAmZQkUuYQJf5cha3-30CyXhmJQ0ukmAGLZi9WzyIVum0J39Pjp5FJfEnpB7XJi8wN3niq2Ig]Newzed@a...[/url
Sendt: 1. juni 2002 22:12
Til: basicstamps@yahoogroups.com
Emne: Re: [noparse][[/noparse]basicstamps] Program slots
For Jim
For one thing, make sure all the variables and cons in slot 0 are also in
slot 3.
Sid
Trygve
Opprinnelig melding
For Jim
slot 3.
Sid
