TLC 1549 ADC w/ stamp
Archiver
Hi all,
I'm trying to get a TCL1549 10bit ADC to send data to my bs2 with no
real success. I had it working with an 8bit ADC0831 (ala' basic
stamp lessons...) and it was working fine. I switched over to the
10bit one, changed my code to reflect a 10 bit ADC as well as the
pin assignments, but the data I'm getting back isn't right. (I am
getting data, it just makes no sense).
The binary value of adcBits gets changed each time through the
loop. If the sensor is outputing 0V the binary vaule cyles between
0 and 100, but sometimes 1000. Shouldn't I at least be getting
0000000000, 0000000100, etc. (?) If the output is 5V, the binary
reading is 1111111111, 1111111101, or 1111111011
In looking at the data sheet for the component I seems that the data
should be getting sent most significant bit post (I'm trying to use
mode 1).. but I'm by no means and must confess I don't understand
most of the datasheet. HELP! Code is below. Sorry for such a long
post.
'{$STAMP BS2}
' DECLARATIONS FOR DATA TRANSMISSION FROM ADC
'******VARIABLES******
adcbits var word
'*****CONSTANTS******
CS CON 11
CLK CON 12
DO CON 13
' OTHER DECLARATIONS
s1Reading var word
'used to keep track of the current sensor readings
adcResolution CON 1024 'the
resolution of the ADC in use.
' ****** PROGRAM BODY ******
debug cls
'Open the debug screen and clear it
' START MAIN PROCEDURE THAT CALLS ALL OTHERS
PAUSE 500
GOSUB MAIN
MAIN:
high 8
'setup pin1 on multiplex for sensor1
low 9
low 10
GOSUB getCurrentVoltage
s1Reading = (100 * adcbits)/adcResolution
'The percentage of the reading between 0 - 5V
GOSUB DISPLAY
goto MAIN
' getcurrentVoltage takes in the current
' voltage reading via serial data, and inputs
' it into adcbits
getCurrentVoltage:
high CS
'go high on the CS pin of the ADC0831
low CS
'go low on the CS pin.. ADC now primed for transmission
low CLK
pulsout CLK,210
shiftin DO,CLK,msbpost,[noparse][[/noparse]adcbits\10]
'current binary reading is put into adcbits
RETURN
' DISPLAY is used to ouptut the current readings
DISPLAY:
debug home
'go to first line of debug window
debug CR, "s1BINARY = ", bin adcBits
debug CR, "s1Int = ", dec3 s1Reading
pause 1000
debug cls
RETURN
post.
'{$STAMP BS2}
adcbits var word
CS CON 11
CLK CON 12
DO CON 13
s1Reading var word
debug cls
PAUSE 500
GOSUB MAIN
MAIN:
high 8
low 9
low 10
GOSUB DISPLAY
goto MAIN
' it into adcbits
getCurrentVoltage:
high CS
low CS
low CLK
pulsout CLK,210
RETURN
DISPLAY:
debug home
pause 1000
debug cls
RETURN
The data sheet you said, wants you to use msbpost. Try using lsbfirst and
see what you get, the data sheet
maybe written for another type of microcontroller with a slightly different
meaning for msbpost and lsbfirst. The
difference might be as to where the start reading data begins on the clock
pulse. See if lsbfirst works and let
us know the results. I do not have the data sheet for the TCL1549, but I will
try to find one and see if I can
see what you need to do for changes from the ADC0831. Most ADC chips I have
experienced have similar code but
with slightly different meanings as how to apply them, because of the type of
microcontroller used to make the
data sheets.
Have Fun !!
Dale Fleischmann
sailing711 wrote:
> Hi all,
> post.
> '{$STAMP BS2}
> adcbits var word
> CS CON 11
> CLK CON 12
> DO CON 13
> s1Reading var word
> debug cls
> PAUSE 500
> GOSUB MAIN
> MAIN:
> high 8
> low 9
> low 10
> GOSUB DISPLAY
> goto MAIN
> ' it into adcbits
> getCurrentVoltage:
> high CS
> low CS
> low CLK
> pulsout CLK,210
> RETURN
> DISPLAY:
> debug home
> pause 1000
> debug cls
> RETURN
Found the data sheets for the TLC1549, and in your program you have one line
the reads;
adcResolution CON 1024 'the resolution of the ADC in
use.
in the data sheet this value should be 512 not 1024, this may also be your
problem(s) you are experiencing.
Also, do you have the -Vref tied to ground or some negative voltage, if it is a
negative voltage change it to ground.
The Basic Stamp does not like negative numbers and changes them to the two's
compliment, example -3 would be changed
to -3 * -3 = 9 or -3 squared, -2 would equal 4, etc. Try all of the suggestion
I have made one at a time and see if
anyone of them makes any difference, before going to the next on. If no change
go back to the original code then try
the next suggestion, you may end up making more then one change before things
start to work correctly. With all the
suggestions I have made there is 6 different combinations you need to try, see
what each does before going to the next
suggestion.
Have Fun !!
Dale Fleischmann
Dale Fleischmann wrote:
> Hi,
> data sheets.
> Have Fun !!
> Dale Fleischmann
> sailing711 wrote:
> > Hi all,
> > post.
> > '{$STAMP BS2}
> > adcbits var word
> > CS CON 11
> > CLK CON 12
> > DO CON 13
> > s1Reading var word
> > debug cls
> > PAUSE 500
> > GOSUB MAIN
> > MAIN:
> > high 8
> > low 9
> > low 10
> > GOSUB DISPLAY
> > goto MAIN
> > ' it into adcbits
> > getCurrentVoltage:
> > high CS
> > low CS
> > low CLK
> > pulsout CLK,210
> > RETURN
> > DISPLAY:
> > debug home
> > pause 1000
> > debug cls
> > RETURN
