Program slots — Parallax Forums
Program slots
edited 2002-06-16 07:05 in General Discussion
I have a program that runs fine on a BS2P40 in program slot 0. But
if I load this program in slot 3, and call it from slot 0, the
results are incorrect. I am printing the results from within the
program, whether in slot 0 or slot 3, but getting different results.
The results when run in slot 0 are correct. What am I doing wrong?
Jim
    edited 2002-06-01 21:11
    For Jim
    For one thing, make sure all the variables and cons in slot 0 are also in
    slot 3.
    Sid
    edited 2002-06-15 23:45
    results.
    > Jim
    Hi Jim:
    Last year, I went through torture with this one. I spend two days up
    at Parallax trying to find the answer. John Barrowman finally found
    it. Under certain conditions, the program would crash at a "RUN"
    command. It turned out [noparse][[/noparse]after many hours of testing] that immediately
    before, during and just after the RUN, if there is anything moving on
    the SERIN line, the firmware interprets that as a programming
    command. I had to put a transmission gate [noparse][[/noparse] CMOS 4066] between the
    SERIN line and the outside world. Trning off the TG cleaned up that
    line, and the problem disappeared. what the oterrs are saying it also
    true. Have exactly the same stack of vars declared in each slot. BUT,
    if the SERIN line has anything on it, watch out!
    I use the commercial version - separate interpreter chip, memory,
    etc, not the module. I don't know if this is true for the modules.
    George
    edited 2002-06-16 01:05
    There is information on our web page about getting your BS2p updated to
    eliminate this problem. The I2CIN and I2COUT syntax was also updated to be
    made a bit more flexible.
    -- Jon Williams
    -- Parallax
    In a message dated 6/15/02 5:46:09 PM Central Daylight Time,
    csiaero1@p... writes:
    > results.
    > > Jim
    > Hi Jim:
    > George
    George,
    I think the problem I had was lining up var in each slot. I did not want to
    use the same variables in each slot (program) because I had run out of space.
    So I used different variables in each slot and passed info via scratchpad.
    This cleared up the problem, so I assumed it was not working because I did
    not have variables lined up. By using scratchpad and different variable
    names in each slot, I saved alot of space and passed my data without
    bothering to line up vars.
    Program slot 0
    a var word
    b var word
    Put 1, a
    Put 2, b
    Run 1
    Program slot 1
    c var word
    d var word
    Get 1, c
    Get 2, d
    This causes c=a and b=d in slot 1
    Could have been what you suggested also, I have a serial backpack on my LCD,
    but it works fine now with above approach.
    Jim
