DS2450 1-Wire Quad A/D Converter and BS2P Stamp to wed this...
Here is some pbasic code to look at for the DS2450. Be sure an look at the
Dallas data sheet for the DS2450.
Chuck
'setup for 1-wire Dallas DS2450
'steps 1 thru 3 per data sheet
'4.7k Ohm 5v pullup on DS2450 pins 5 and 6
'100k Ohm potentimeter pot on DS2450 pin 8 to vary voltage input, 0 to 5v
'9/24/00
r var byte(12)
x var word
y var byte
z var byte
w var byte
j var byte
p var nib
s var nib
afl var y.bit4
afh var y.bit5
s=8
gosub INIT
pollin 0,0
pollin 1,0
pollout 9,1
pollmode 2
p=4
'Step 1 of data sheet, page 16
owout p,1,[noparse][[/noparse]$cc,$55,$08,$00,$c0]
owin p,0,[noparse][[/noparse]r(0),r(1),r(2)]
owout p,0,[noparse][[/noparse]$00]
owout p,0,[noparse][[/noparse]$c0]
owout p,0,[noparse][[/noparse]$0c]
owout p,0,[noparse][[/noparse]$0d]
'Step 2 of data sheet, page 17
owout p,1,[noparse][[/noparse]$cc,$55,$16,$00,$64]
owout p,0,[noparse][[/noparse]$96]
owin p,0,[noparse][[/noparse]r(3),r(4),r(5)]
owout p,1,[noparse][[/noparse]$cc,$3c,$08,$40]
owin p,0,[noparse][[/noparse]r(6),r(7)]
xx:
owin p,0,[noparse][[/noparse]r(8)]
if r(8)=$ff then yy
goto xx
yy:
owout p,1,[noparse][[/noparse]$cc,$aa,$0f,$00]
owin p,0,[noparse][[/noparse]r(9),r(10),r(11)]
z=$c0:w=$c0
zzz:
'Step 3 of data sheet, page 18
owout p,1,[noparse][[/noparse]$cc,$55,$08,$00,z]
owout p,0,[noparse][[/noparse]w]
owin p,2,[noparse][[/noparse]r(6),r(7),r(8)]
zz:
owout p,1,[noparse][[/noparse]$cc,$55,$0f,$00,$0d]
owin p,2,[noparse][[/noparse]r(0),r(1),r(2)]
owin p,0,[noparse][[/noparse]r(0),r(1)]
pause 5 'delay for convert
ww:
owin p,0,[noparse][[/noparse]r(2)]
if r(2)=$ff then vv
goto ww
vv:
owout p,1,[noparse][[/noparse]$cc,$aa,$06,$00]
owin p,2,[noparse][[/noparse]r(0),r(1)]
x=((((r(1)*256)+r(0))/256)*5)*4
debug dec x," mv ",cr
lcdout s,2,[noparse][[/noparse]dec4 x,"mv "]
if r(0)>$0d then res
pause 500
z=$c0:w=$c0
goto zzz
res:
debug hex2 r(0)," alarm",cr
'goto zz
auxio
y=r(0)
z=$80:w=$80
if afl=1 then res2
z=$c0
goto res5
res2:
lcdout s,128+7,[noparse][[/noparse]$3c]
res5:
if afh=1 then res3
w=$c0
goto res4:
res3:
lcdout s,128+7,[noparse][[/noparse]$3e]
res4:
mainio
pause 500
get 128,j
debug bin8 j,cr
'pollmode 2
goto zzz
INIT
lcdcmd s,48 'set function
pause 5
lcdcmd s,48
pause 0
lcdcmd s,48
pause 0
lcdcmd s,32
pause 0
lcdcmd s,44
pause 0
lcdcmd s,8 'display off
lcdcmd s,12 'display on
lcdcmd s,6 'set mode
return
Chuck
'9/24/00
r var byte(12)
x var word
y var byte
z var byte
w var byte
j var byte
p var nib
s var nib
afl var y.bit4
afh var y.bit5
s=8
gosub INIT
pollin 0,0
pollin 1,0
pollout 9,1
pollmode 2
p=4
xx:
if r(8)=$ff then yy
goto xx
yy:
z=$c0:w=$c0
zzz:
zz:
ww:
if r(2)=$ff then vv
goto ww
vv:
pause 500
z=$c0:w=$c0
goto zzz
res:
'goto zz
auxio
y=r(0)
z=$80:w=$80
if afl=1 then res2
z=$c0
goto res5
res2:
res5:
if afh=1 then res3
w=$c0
goto res4:
res3:
res4:
mainio
pause 500
get 128,j
debug bin8 j,cr
'pollmode 2
goto zzz
INIT
pause 5
lcdcmd s,48
pause 0
lcdcmd s,48
pause 0
lcdcmd s,32
pause 0
lcdcmd s,44
pause 0
return
