GPS Module
Archiver
At Parallax we tend to use the Garmin eTrex family (handheld) for our
experiments. The cables are expensive, but we've found some decent 3rd party
sources.
-- Jon Williams
-- Parallax
In a message dated 5/30/02 12:22:47 PM Central Daylight Time,
mwaddell@s... writes:
> I keep reading about GPS modules that some people are using. Is
> this the same as a hand held unit or is it a specialty device with
> just a serial output. Can someone give me a link to some
sources.
-- Jon Williams
-- Parallax
4800 buad, N81. There are several "legal" NMEA sentences,
including GPGGA and GPRMC which are the most popular.
Pfranc makes some inexpensive Garmin cables.
Paul
> sources.
> -- Jon Williams
> -- Parallax
messed up this morning.
information or straiten out my confusion.
Mark
see what I come up with.
Mark
> 3rd party sources.
> -- Jon Williams
> -- Parallax
> and Body of the message will be ignored.
Look at:
www.axiomnavigaton.com
The swift B1 works well
mike m
Sent: Thursday, May 30, 2002 1:46 PM
Subject: [noparse][[/noparse]basicstamps] GPS Module
> I am sending this again because I think my email system was
> Thanks
> Mark
Stan
--- In basicstamps@y..., "mocenter" <mocenter@e...> wrote:
> Dear Mark,
> Look at:
> mike m
> From: <mwaddell@s...>
> To: <basicstamps@y...>
> > Thanks
> > Mark
> > basicstamps-unsubscribe@y...
mike m
Sent: Thursday, May 30, 2002 7:21 PM
Subject: [noparse][[/noparse]basicstamps] Re: GPS Module
> I think you meant www.axiomnav.com
> Stan
> > Dear Mark,
> > Look at:
> > mike m
> > > Thanks
> > > Mark
and
and antenna. They are usually more expensive than consumer units
though. These are about the lowest cost ones I've seen;
http://www.laipac.com/products/gps.htm
> Thanks
> Mark
Just FYI. the units laipac is selling in Canada are "old" modules mfg in
Taipei a long time ago. The SIRF I chip set has been around for a long time
and was replaced about 3 years ago with the SIRF II chipset and sometime
this year (?) they will have a low power version SIRF LP. The problem for
portable apps with this chip set is that they draw around 150mA at
continuous mode and the others that are about the same price OEM's, draw
around 30-40 mA which is considerable for battery life. I have an
assortment of all of these OEM's for my eng and they all have a low level
RS232 signal TXD and RXD, but just add the MAX 3232 chip and it puts out the
right levels. Small active patch antennas are widely available and most are
"good" receivers, but remember GPS is as good as GPS gets. You need good
visibility on the low angles of the horizon to get "good" fixes most of the
time. good luck
mike m
Sent: Friday, May 31, 2002 10:04 AM
> Most companys make OEM GPS modules. You supply the case,RS232 drivers
> > Thanks
> > Mark
souces?
Troy S.
jonwms@a... wrote: At Parallax we tend to use the Garmin eTrex family
(handheld) for our
sources.
-- Jon Williams
-- Parallax
from the same email address that you subscribed. Text in the Subject and Body of
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
Do you have suggestions for other low power GPS modules?
Chris
Dear replier ( name not shown)
time
for
the
are
the
time. good luck
mike m
> > Thanks
> > Mark
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/web/.
