SERIN auto-looping?
Archiver
This one's got me really baffled. I'm using a BS2p24. I'm reading
output from a VB script. The data comes as one continuous stream of
30 numbers, but I wanted to separate the data into 6 sets of 5. I
had problems and began debugging the original code. The long and
short of it is, I got the code down to the following:
Data VAR BYTE
SERIN 16,16624,[noparse][[/noparse]DEC DATA]
SEROUT 14,16624,[noparse][[/noparse]DEC DATA,","]
END
Pin 14 is connected to a terminal prog on another PC to monitor
the data. I expected to see one number and comma come through and
nothing else, i.e.:
49,
However, it still receives and echoes all the data, and the output
looks like:
49,12,10,12,11,61,12,12,12,13,40,12,14,12,15,6,12,16,12,17,29,12,18,12
,19,16,12,20,12,21
Is SERIN and SEROUT causing some kind of auto-loop? Any ideas
what's going on? This is totally bizarre!
Data VAR BYTE
END
nothing else, i.e.:
49,
looks like:
,19,16,12,20,12,21
-12V from the PC. If you are trying to "watch" both lines with port 16
or if your code on the other end is echoing that could cause a loop. You
can read more about the auto echo "feature" at the Stamp FAQ at
http://www.wd5gnr.com/faqs
Good luck!
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: mtlhead7 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mE7yyOfZGCk73rq7ABDvP_BoE24s5i2p9_P1XaVylt-ZsF8l1UG6T3_kcExednd3AeN8pv5Ikko2qZKeEWCTx5rOL0pmJQ]renegade.engineer@v...[/url
> Sent: Tuesday, May 28, 2002 7:02 PM
> Subject: [noparse][[/noparse]basicstamps] SERIN auto-looping?
> Data VAR BYTE
> END
> nothing else, i.e.:
> 49,
> looks like:
> ,19,16,12,20,12,21
> from the same email address that you subscribed. Text in the
I'm not sure I understand your answer. I tried the FAQ, but got no
results when I searched on 'auto' or 'echo' or both.
More info might help here. I'm transmitting from a simple output-only
VB script on one PC in through port 16 and then the stamp is forwarding what
it receives out port 14 to a receive-only terminal on another PC. This is
what I intended to happen. Where I'm confused is why the stamp is receiving
more than one piece of data. The code I spelled out below is supposed to
only get one number, relay that number and a comma, and stop. But it
doesn't. It continues to receive all the incoming numbers. That's the part
that I can't figure out. It should only get one number. The fact that it
continues to echo what it receives is unimportant.
Any ideas?
Don
Sent: Tuesday, May 28, 2002 6:27 PM
Subject: RE: [noparse][[/noparse]basicstamps] SERIN auto-looping?
> Don't forget that port 16 always echos what you send it since it steals
> Good luck!
> Al Williams
> AWC
> > From: mtlhead7 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JGX_-OJau_uN289I7EUUGn4zrNpfWAL08SqHfU_Yd3Bm0ILP-cW2IRoAnhi_Ww8zN9lCfpmU4LN7yHZYthOFrJgroA]renegade.engineer@v...[/url
> > Data VAR BYTE
> > END
> > nothing else, i.e.:
> > 49,
> > looks like:
> > ,19,16,12,20,12,21
http://www.wd5gnr.com/faqs/index.php?qframe=1&faq=1&article=35
Not sure if that is your problem or not, but I'd wager that if you got
off port 16 your problem would mysteriously clear up.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fIBz3NAVRCYihBw_9i1P7uvHkoLZA7Cs42o34DzmtdkHRvlXn1xYRXNs5jguTMSIRSn03GzYUmUQAdRMIWtbY-cWRwRO8J8]renegade.engineer@v...[/url
> Sent: Tuesday, May 28, 2002 9:47 PM
> Subject: Re: [noparse][[/noparse]basicstamps] SERIN auto-looping?
> Al
> but got no results when I searched on 'auto' or 'echo' or both.
> simple output-only VB script on one PC in through port 16 and
> then the stamp is forwarding what it receives out port 14 to
> a receive-only terminal on another PC. This is what I
> receiving more than one piece of data. The code I spelled
> out below is supposed to only get one number, relay that
> number and a comma, and stop. But it doesn't. It continues
> to receive all the incoming numbers. That's the part that I
> that it continues to echo what it receives is unimportant.
> Any ideas?
> Don
> From: "Al Williams" <alw@a...>
> > steals -12V from the PC. If you are trying to "watch" both
> lines with
> > port 16 or if your code on the other end is echoing that
> could cause a
> > loop. You can read more about the auto echo "feature" at
> the Stamp FAQ
> > at http://www.wd5gnr.com/faqs
> > Good luck!
> > Al Williams
> > AWC
> > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> > > From: mtlhead7 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fIBz3NAVRCYihBw_9i1P7uvHkoLZA7Cs42o34DzmtdkHRvlXn1xYRXNs5jguTMSIRSn03GzYUmUQAdRMIWtbY-cWRwRO8J8]renegade.engineer@v...[/url
> > > reading output from a VB script. The data comes as one
> continuous
> > > stream of 30 numbers, but I wanted to separate the data
> into 6 sets
> > > of 5. I had problems and began debugging the original code. The
> > > long and short of it is, I got the code down to the following:
> > > Data VAR BYTE
> > > END
> to monitor
> through and
> > > nothing else, i.e.:
> > > 49,
> > > output looks like:
> > > 12
> > > ,19,16,12,20,12,21
> the Subject
> > and
help!!
Don
Sent: Tuesday, May 28, 2002 8:01 PM
> The article in question is
> Al Williams
> AWC
> > From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N160dJapl1w49AGEjsrFvXxUjDyPjaPcz0-42QhDNhlUXTiyfnK0W8N-RTRhCDLCIlObvUgrv26B8FcTTGRDzMQQRP_SwA]renegade.engineer@v...[/url
> > Al
> > Any ideas?
> > Don
> > lines with
> > could cause a
> > the Stamp FAQ
> > > Good luck!
> > > Al Williams
> > > AWC
> > > > From: mtlhead7 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N160dJapl1w49AGEjsrFvXxUjDyPjaPcz0-42QhDNhlUXTiyfnK0W8N-RTRhCDLCIlObvUgrv26B8FcTTGRDzMQQRP_SwA]renegade.engineer@v...[/url
> > continuous
> > into 6 sets
> > > > Data VAR BYTE
> > > > END
> > to monitor
> > through and
> > > > nothing else, i.e.:
> > > > 49,
> > > > output looks like:
> > > > 12
> > > > ,19,16,12,20,12,21
> > the Subject
> > > and
repeat the program over and over. This happens often if the PC
terminal program manipulates DTR. To determine if this is the case:
Data VAR BYTE
SEROUT 14,16624,[noparse][[/noparse]"Begin"]
END
The "Begin" message will only be transmitted at the start of the
program, so if you see it more than once your program is restarting.
See the SERIN/SEROUT instructions in the manual to see how to get
past this problem if appropriate.
Steve
using a different input pin will fix the problem, but now I know what was
going on as well.
Thanks again to everyone!
Don
Sent: Tuesday, May 28, 2002 10:44 PM
> My guess: your transmitting PC is causing your Stamp to reset and
> Data VAR BYTE
> END
> Regards,
> Steve
Our ASP-II has a jumper to disconnect DTR for just this reason. You
might consider something similar -- you could isolate DTR when operating
and resume it while programming. You can also sometimes set your PC
software to leave DTR alone (for example, handshaking=none).
Al Williams
AWC
> From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZzOI6tSN6yJMXerRz7GKbj8iLqn7WBCbU8-7iN3u5sF-iTaJRYRrBH7i4tbRMNlFVSo7NWnmYH-o9xBSe7ozIy4GfQ]renegade.engineer@v...[/url
> Sent: Wednesday, May 29, 2002 8:42 AM
> YES! That's the problem. Thanks Steve! Looks like Al's
> suggestion of using a different input pin will fix the
> problem, but now I know what was going on as well.
> Don
> From: "S Parkis" <parkiss@e...>
> > Data VAR BYTE
> > END
> restarting.
> to get past
> > Regards,
> > Steve
> the Subject
> > and
