Video Recorder - Turn Record on/off — Parallax Forums
edited 2002-05-30 10:25 in General Discussion
Hi Folks,
I've got a home security project and I need your help. I want to make a
video recorder start and stop recording remotely. I've got a stamp which
collects info from various sources. I want to keep the unit on record all
the time but on pause. When the stamp identifies someing to record I want to
take the pause off. After a few seconds it will then turn the unit back to
pause.
I suppose I could make the stamp "learn" the pwm from an infra-red control
unit, but I prefer a wired connection. Is there something simple I can do
without buying a special recorder or breaking open my domestic recorder -
can I use the scart connections somehow?
Tony
    edited 2002-05-28 13:38
    Hi Trygve,
    I've been looking at units that "fake" the video remote controll - so I
    could use the stamp in the same way. I just prefer a wired connection as I
    can be *certain* that the video unit is recording....Otherwise I'll end up
    recording all the adverts (!)
    Tony
    Sent: Tuesday, May 28, 2002 1:18 PM
    Subject: SV: [noparse][[/noparse]basicstamps] Video Recorder - Turn Record on/off
    > Greetings!
    > I don't think you have any signals for that in the SCART connector, but
    have
    > you considered another 'low tech' approach, like using a solenoid to
    'punch'
    > the buttons on the recorder?
    > (Can then be made to fit any new recorder when the old breaks)
    > But I'm afraid that you may have to look for another recorder.
    > Most commercial recorders will automatically STOP when it's been paused
    for
    > a few minutes.
    > Typically, a little too short pause for it to span looooong commercial
    > breaks...
    > Trygve
    Opprinnelig melding
    > Fra: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VTQk8x8nhQWRHkxupeztzhw0C-1JUgC8C2WnaV6keoQAupzNRo0C3aP3sRBc2yBOkt3Ra7-_I15Qd1EzpAKiBHLx]tony.wells@a...[/url
    > Sendt: 28. mai 2002 14:10
    > Til: basicstamps@yahoogroups.com
    > Emne: [noparse][[/noparse]basicstamps] Video Recorder - Turn Record on/off
    > Hi Folks,
    to
    > pause.
    > Thanks
    > Tony
    > Body of the message will be ignored.
    edited 2002-05-28 13:50
    Be advised that most video recorders support pause (when recording) for only few
    minutes. After that time (around
    5 minutes) it desengages the pause AND recording mechanism in order to preserve
    video heads from excessive wear.
    ACJacques
    tony.wells@a... gravada:
    > Hi Folks,
    > pause.
    > Thanks
    > Tony
    edited 2002-05-28 20:37
    > pause.
    It is my experience that any video tape recording
    device will not remain in PAUSE mode for any length of
    time, due to the fact that the heads overheat, and the
    system shuts down. Every VCR or Camcorder I have ever
    owned does this...
    You would need to initiate record mode and stop
    instead. But remember, some units even power down
    after extended periods of no activity.
    Chris
    __________________________________________________
    Do You Yahoo!?
    Yahoo! - Official partner of 2002 FIFA World Cup
    http://fifaworldcup.yahoo.com
    edited 2002-05-28 21:45
    Thanks Chris,
    I think I just didn't explain properly - yes I understand about the pause
    business and the recorder stopping if held for a while in record mode etc
    etc.
    The underlying control problem is still there however. I take it from the
    lack of replies on this basic control issue is that there is no easy way of
    controlling this type of function apart from emulating the remote control
    unit??? I did wonder if the scart connector has some kind of control wire.
    But I could only find one-word descriptions of each wire in the scart
    control spec - a bit opaque to me.
    Tony
    Sent: Tuesday, May 28, 2002 8:37 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Video Recorder - Turn Record on/off
    > > pause.
    > owned does this...
    > Chris
    > Do You Yahoo!?
    edited 2002-05-28 22:17
    SCART connector does not implement recording or pause functions. Do a web search
    and you will find may references.
    There are some SONY proprietary control called LANC or Control L used in
    semiprofessional VCR´s that have this
    function.
    ACJacques
    > Thanks Chris,
    > etc.
    > Thanks,
    > Tony
    > From: "Chris Savage" <knight_designs@y...>
    > > > pause.
    > > owned does this...
    > > Chris
    > > Do You Yahoo!?
    edited 2002-05-28 22:57
    You should note that most consumer VCRs won't stay paused more than about
    4-5 minutes. This is because the head is spinning against the tape and it
    will eventually wear the tape so bad it won't record.
    to
    > pause.
    edited 2002-05-28 23:08
    Back in the dark ages before camcorders, there were actual video cameras (no
    recorder) that plugged into a VCR. The VCR's also had a mono mini or
    sub-mini receptacle on them for a pause control. A simple normally-open
    switch would start / stop the recording.
    of
    edited 2002-05-28 23:19
    please delete me from mailing list now!
    > pause functions. Do a web search and you will find
    > may references.
    > or Control L used in semiprofessional VCR´s that
    > have this
    > function.
    > ACJacques
    > > Thanks Chris,
    > > etc.
    > > Thanks,
    > > Tony
    > Record on/off
    > your
    > remotely.
    > keep
    > identifies
    > will then
    > > > > pause.
    > recording
    > length of
    > and the
    > have ever
    > > > owned does this...
    > down
    > > > Chris
    > > > Do You Yahoo!?
    > Text in the Subject and Body of the message will be
    > ignored.
    > ignored.
    Do You Yahoo!?
    edited 2002-05-28 23:36
    Dear Tony,
    I believe, although I may be alone here, that the stamp is capable of
    generating the codes necessary to do the job you need. I have tried but
    I can't seem to figure out what the IR codes are in a pure sense of the
    term. I have an old scope that's only good for a 100 MHz or so, but
    fast enough to see the signals from an IR remote. The signals are
    generated once when a button is pressed and then a maintenance signal
    follows. If I had a good storage scope or one of the scope devices to
    put on a parallel port, I think this could be made to work. The stamp
    is capable of putting out pulses in the microsecond range and these IR
    devices are in the Milli second range. Just my $0.02.
    leroy
    > Hi Folks,
    > pause.
    > Thanks
    > Tony
    edited 2002-05-29 00:47
    The X10 unit has IR emitters that you stick(clear sticky stuff) to the front of
    the VCR
    by the IR detector.
    > Hi Trygve,
    > Thanks,
    edited 2002-05-29 02:40
    You may simply want to try to use a USB port digital camera with animation
    or movie capability and record the digital
    files directly to your PC. Except for the hard disk you would basically have
    no moving parts.
    A number of the software packages have some sort of control or batch
    capability that should work for remote control.
    Other software packages actually can detect movement and record accordingly.
    If your doing something like time lapse photography then you shouldn't have
    any problems controlling a digital camera of some sort.
    In the worse case you could use a Stamp to send commands to the keyboard
    port and trick the PC into starting and stopping and saving out the file by
    sending the appropriate keyboard commands to the PC. They've discussed that
    at length here in the past too.
    From: ACJacques [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jixYSiGw0C5UI5Wa4bUwVxOl4m-cXKLhtYcFQgJIKxBRctPT8yFgwACrHjJNKS4vNXGihh_NREVMIAHdgJd19g]acjacques@i...[/url
    Sent: Tuesday, May 28, 2002 4:18 PM
    search and you will find may references.
    function.
    ACJacques
    > Thanks Chris,
    > etc.
    of
    > Thanks,
    > Tony
    > > > pause.
    > > owned does this...
    > > Chris
    > > Do You Yahoo!?
    and
    edited 2002-05-29 05:12
    > Thanks Chris,
    > etc.
    Well, after that I can't help you, since my knowledge
    of IR control systems is limited. Good luck.
    Chris
    Do You Yahoo!?
    edited 2002-05-29 09:27
    Hi Tony,
    Years ago, I made a little "wired remote control" for my video recorder.
    I mounted a 7-pin DIN socket at the back side. I connected this socket to
    necessary points of the front keyboard of the recorder.
    The remote control is a simple set of pushbutons. The only trick I had do to
    to was to put a resistor (1K or so) between each wire and the ground, inside
    to remote box, to avoid strange behaviour of the recorder.
    In your case, you need to simulate a push on the "REC" button (if it's a
    one-key command). You could do it with a little relay attached inside your
    recorder, and energized by the Stamp (via a transistor eventually). And of
    course, the same applies for the "STOP" button...
    Hope this helps.
    Phil.
    Subject: [noparse][[/noparse]basicstamps] Video Recorder - Turn Record on/off
    > Hi Folks,
    to
    > pause.
    > Thanks
    > Tony
    edited 2002-05-30 08:22
    A simple resolution may be to buy a cheap universal remote and hard wire your
    stamp to it, rather than hack you VCR or try to emulate the IR code?
    Troy S.
    tony.wells@a... wrote: Hi Folks,
    pause.
    Tony
    from the same email address that you subscribed. Text in the Subject and Body of
    Do You Yahoo!?
    Hi Troy,
    Yes, that seems the way to go. What I really need is VCR with an ethernet or
    bluetooth connection...
    Tony
    Sent: Thursday, May 30, 2002 8:22 AM
    your stamp to it, rather than hack you VCR or try to emulate the IR code?
    > Troy S.
    to
    > pause.
    > Thanks
    > Tony
    > Do You Yahoo!?
