Interfacing w/RC Receiver
Hello,
I am considering purchasing the Basic Stamp 2SX for use in a project
that I am working on, but I would like some expert opinion about it's
abilities.
Here is a list of what I am trying to do:
1)Decode 2 channels of a Remote Control signal (1-2ms pulses centered
at ~1.5ms and repeated each 20-30ms) so that I can use this data to
drive a pair of motors via PWM output to a pair of H-Bridge circuts
for "tank like" operation of a model.
2) Capture data from 2 encoders so that I can preform corrections on
the drive motors (ex. in case one motor tends to run faster than the
other, so I can keep it going straight when there is no reason for it
to be turning).
Anybody know if I am looking at the correct device to accomplish
this, or should I be looking at something else?
If this is possible, has anyone done any thing like this and have any
helpful hints or gotcha's to avoud?
abilities.
to be turning).
classes, the students would usually want to know who was the expert.
The general reply was that an 'ex' is an old has been and a 'spert' is a
drip under pressure. Never the less, seems like a standard radio remote
control does exactly the job of item #1. Item #2 sounds lie a
sophisticated control algorithm, that is probable more in line with a
PIC or a dedicated CPU. Can you do this job with a 2sx? I doubt anyone
here will say yes or no. They would probably give you a guess, but
that's all.
This program will control two servos connected to a BS2, this I have
tried.
HTH
leroy
' Program: PULSOUT.BS2
' This program moves a servo on pin 0 & 3. Connect the servo to I/O
' pin 0 & 3.
' {$STAMP BS2} ' STAMP directive (specifies a BS2)
x var word
Again:
high 1
pause 225
low 1
pause 225
if in2 = 0 then again
high 1
for x = 100 to 1300 step 30
PULSOUT 0, x
PAUSE 25
PULSOUT 3, x
debug "x: ", dec x, cr
next
low 1
for x = 1300 to 100 step 30
PULSOUT 0, x
PAUSE 25
PULSOUT 3, x
'debug "x: ", dec x, cr
next
GOTO Again
mfl_jr wrote:
> Hello,
> abilities.
> to be turning).
> Thanks,
> Mike
things at once on past projects, I've adopted the philosophy of adding
extra PICs in a master-slave configuration to get the job(s) done.
Works every time. So Mike, you might consider adding one or more BS1s,
communicating with your 2SX, if necessary, to accomplish 2-channel
decoding in addition to driving a pair of motors.
Dennis
From: Leroy Hall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8su1Wmdyf4IF0zye8qfwGnP_4gJT1A4v0wrzUcAi_Cw58S7YLj-XAANTHExOKu3FJa-35SwiMA]leroy@f...[/url
Sent: Monday, May 27, 2002 3:48 PM
Subject: Re: [noparse][[/noparse]basicstamps] Interfacing w/RC Receiver
When I was an Instructor at Cincinnati Milacron's Industrial Robot
that's all.
tried.
<deleted>
mfl_jr wrote:
> Hello,
> abilities.
> to be turning).
> Anybody know if I am looking at the correct device to accomplish this,
> Thanks,
> Mike
> and Body of the message will be ignored.
