Magnetic head
I'm construct a system with card with magnetic stripe can anyone show me where i
can find magnetic head read/write/erase?
thank you
thank you
does anyone have any idea how can i write to a
magnetic stripe one bit with a simple circuit?
I have a magnetic head one track who write & read.
thanks
____________________________________________________________
Do You Yahoo!?
hysteresis in the magnetic head, the information is modulated on a "carrier
frequency." But if you want digital info, you could try writing it without
the carrier.
From: andonis konstantinidis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=X1isJup_zxvfgGhb3gG_eme5prf9qv4uwNtUVneONvl-oNSx1oVxa1-6wCboRfwhhTaZV3VauTi3Pjk]andoniskgr@y...[/url
Sent: Tuesday, May 18, 2004 5:56 PM
Subject: [noparse][[/noparse]basicstamps] magnetic head
hello,
thanks
Do You Yahoo!?
For analog recording on magnetic media, there's an ultrasonic bias frequency
applied to the recording head (usually around 40 kHz or so) that is then
modulated by the audio signal. This is done to keep the audio signal within
the linear region of the magnetic record/playback process.
For digital recording on magnetic media, they normally use saturation
recording, where the record head is hit with enough current to saturate the
magnetic media. If you scope at the signal on a floppy drive or hard disk
head, it looks like distorted sine waves at two different frequencies, with
one frequency representing "zero" and other frequency being "one".
I've never messed with mag cards, but I assume it's pretty much the same
thing....
Mike Sokol
mike@f...
www.fitsandstarts.com
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Wednesday, May 19, 2004 10:30 AM
Subject: RE: [noparse][[/noparse]basicstamps] magnetic head
Look up on the web information on how cassette recorders work. Due to the
the carrier.
From: andonis konstantinidis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dh1UY4GYlrwSdIz0dn-I2ajght1cjHHTc75APh-FArLO1tiSDHMr3Ps5pko1hq-CGEVIkd3YiKgKWgA]andoniskgr@y...[/url
hello,
thanks
Do You Yahoo!?
i.e. two channels (a left head and right head). One channel would contain
your data by shifting-up the frequency, shifting-down the frequency, or
pulsing a fixed frequency to represent a "1" or "0". The other channel
would be a baseline fixed frequency or fixed frequency burst representing
a clock pulse. This way the "user"/machine could swipe the card at
relatively any speed and the data can be recovered by simply comparing
the two channels and noting the differences depending on the scheme used.
>Just to expand a bit....
>thing....
>Mike Sokol
>mike@f...
>the carrier.
>hello,
>thanks
Beau Schwabe Mask Designer II National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Mail Stop GA1
