SV: [basicstamps] Making copies of BS2 program without source cod e
Greetings!
It IS possible, but...
1: Desolder the Serial EEPROM on the BS2.
2: Place it in a holder and plug it into an EPORM programmer.
3: Do a file dump of the chip...
4: Up to you...
a: Unsolder the EEPROM's from other BS2's and burn the data onto
them before resoldering them, or
b: Use the file dumt to create a block of DATA statements that you
dump onto other BS2's...
Trygve
'Impossible? - I'll have it on your desk you tuesday, I have a miracle to
perform first'...
Opprinnelig melding
Fra: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zQPGWQ84EVc__ytuoHEIBDxksWgVvqqHVtyOMdV8bb0LbVu5wDZprdf2t0JYo8EnIbPVBVjwKWBFG0hkm_zuKkGhlyZJxqyx]renegade.engineer@v...[/url
Sendt: 24. mai 2002 15:24
Til: basicstamps@yahoogroups.com
Emne: Re: [noparse][[/noparse]basicstamps] Making copies of BS2 program without source code
If you're thinking you would like to 'extract' the program currently
running on your BS2, forget it. I've read several times that the basic
stamps are specifically designed to prevent that for security of a producers
code. I think you're stuck trying the different versions of your code,
perhaps on separate stamps, to see which operates correctly.
Don
Sent: Friday, May 24, 2002 2:34 AM
Subject: [noparse][[/noparse]basicstamps] Making copies of BS2 program without source code
> I apologise if this is a silly question.
> I have a BS2 working in an application and wish to make several copies of
it
> but because I dont know which version of my source code I last used to
> program it (two years ago) I wondered whether I could just duplicate it in
> some way?
> Thanks
4: Up to you...
Trygve
perform first'...
Opprinnelig melding
Don
it
> some way?
> Thanks
