switching AC load problem
Dear Sir,
In my project the BS2 control a solid state relay with zero crossing to
switch on/off 220VAC contactor.The user should press a push-button to start
the operation and then the contactor is switched off when the weight reading
match the setpoint.The problem is some times pressing the push-button
corrupts the transducer A/D operation and I have to press the key which
performs the initial conditions of the A/D again.
How can I solve this problem to guarantee proper operation?
There is 250V varistor across the main.
Thank You
Mohamed Refky
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
Thank You
Mohamed Refky
>switch on/off 220VAC contactor. The problem is some times pressing the
>push-button
Add another varistor right across the coil of the contatctor. If the
contatctor drives an inductive load, also consider adding varistors right
at the load.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
associated with starting a motor drop the voltage to your control
system ?
Have you tried (or are you) powering from a seperate and stabile
source ?
The lights in my house dim whenever the water pump starts. If a
dimmer is on a low setting it will often just turn off the light.
I found powering after a computer battery backup supply stops most of
the problems.
--- In basicstamps@y..., Dwayne Reid <dwayner@p...> wrote:
crossing to
the
> >push-button
which
the
right
> at the load.
> dwayne
an high inductive load as a contactor coil.
Regards
ECO
Sent: Friday, May 24, 2002 11:30 AM
Subject: [noparse][[/noparse]basicstamps] switching AC load problem
> Dear Sir,
> Thank You
> Mohamed Refky
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] switching AC load problem
>Date: Sat, 25 May 2002 10:10:02 +0200
>Not sure, but zero crossing should not be adequate to commute
>Regards
>ECO
Why not
What does a zero-crossing turn-on circuit refer to?
Zero-crossing turn-on and turn-off refer to the point on the AC wave form
when the voltage is zero. It is at this point that an AC SSR will turn on or
off. When the AC circuit voltage is at zero, no current is flowing. This
makes it much easier and safer for the semiconductor device in the relay to
be turned on or off. It also generates much less electrical EMI/RFI noise
>From: "Mohamed REFKY" <refky@h...>
> > Dear Sir,
>start
>reading
> > Thank You
> > Mohamed Refky
>and Body of the message will be ignored.
Send and receive Hotmail on your mobile device: http://mobile.msn.com
voltage of 0 volts, but it turns off, if switched by a TRIAC or SCR when
the line current is zero. Because of the inductive characteristics of
the load, this point probably won't coincide with the zero crossing of
the line voltage. when you build a magnetic field up in a coil by
running current through it, it continues giving current back until that
field has collapsed. Just so you understand, the theory behind the
thing. Hope this helps and as always I am sure I have stated something
not quite correctly. I do this so that others can have their two cents
worth and the whole group can understand exactly what is going on.
HTH,
Leroy
> >From: "ECO" <ecourt@b...>
> >Regards
> >ECO
> Why not
> > > Dear Sir,
> >start
> >reading
> > > Thank You
> > > Mohamed Refky
