Auto-OBDII scanners
Archiver
I am attempting to read in data from the OBDII port in a car (Toyota which
uses ISO protocol). Has anyone done this successfully with a stamp? I
have seen rather expensive scanners out there and was hoping I might be
able to do it with a stamp. Thanks in advance, Dan : )
Sometimes it is cheaper to buy the wheel than to re-invent it.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=46030
I have this reader and it works great with my 97' Silverado 4x4. For
50 bucks does it really make sense to buy a stamp for the same cost
and then have to hack the pbasic and scrounge for a OBDII connector.
Sometimes HF sells this for $39. Watch for the sales.
Jason
(Toyota which
stamp? I
might be
I can't catch with the built-in diagnostic indicator and not having OBDII
makes it alot more expensive.
I was thinking all OBDII connectors and protocols are the same. They just
implemented dyno testing for our annual inspection and all the shops can
jack into the newer cars and use the onboard computer to check sensors,
etc...
> (Toyota which
> stamp? I
> might be
etc...
> (Toyota which
> stamp? I
> might be
outputs for reading sensors that cover emission standards. I have a new
02' Toyota Prius hybrid which has a multitude of cool sensors which are
just waiting to be read. From what I have researched, the ISO protocol
which Toyota uses is more difficult to read and the Prius specific codes
may only be read with their $5,000 scanner. I was hoping to possibly read
in raw data and somehow decipher which codes refer to what sensor. Ford,
GM and Chrysler/imports use slightly different coding requiring different
software. Thanks for the lead through HF, I'll look into it. Software
seems to be the weakest link. Dan : )
Wish they had one that cheap for a '94 Dodge PU -- mine has some soft
errors
etc...
> (Toyota which
> stamp? I
> might be
