SV: SV: [basicstamps] BS2P problem
Greetings!
Do you have any DATA on it?
A tech sheet or a .PDF file would be handy.
(Or a name and link to the producers site)
What kind of software did you use when you tested it with the PC?
Trygve
Opprinnelig melding
Fra: wanyia [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_HQ-nLuNEAQjo_I9RXjvNR8sunEPEO_5hbzaU8bsZqrxrqQsBedqWq3L9LFJ3H2Z3lagFLUBfr0]wanyia@y...[/url
Sendt: 23. mai 2002 15:38
Til: basicstamps@yahoogroups.com
Emne: Re: SV: [noparse][[/noparse]basicstamps] BS2P problem
Hi! Trygve,
I am using capacitive level sensor. With this sensor, it can with
pc via serial port. then i connected it with bs2p with null modem
connection. Thank you very much for taking your time[noparse]:)[/noparse]
--- In basicstamps@y..., Trygve Henriksen <trygve.henriksen@v...>
wrote:
> Greetings!
> What kind of sensor are you using?
> Trygve
Opprinnelig melding
> Fra: wanyia [noparse][[/noparse]mailto:wanyia@y...]
> Sendt: 23. mai 2002 15:26
> Til: basicstamps@y...
> Emne: [noparse][[/noparse]basicstamps] BS2P problem
> Hi All,
> Now i am doing my basic stamp project using BS2p to recieve
and
> read the data from the sensor. I am really new for programming and
> also basic stamp. As well, i met the problem for recieving and
> reading the data from sensor. here is my code:
> data1 var byte
> input 7
> serin 7, 18447, [noparse][[/noparse]dec data1]
> How can i do if i wanna read the data from the sensor as well?
> basicstamps-unsubscribe@y...
> from the same email address that you subscribed. Text in the
Subject and
> Body of the message will be ignored.
Trygve
Opprinnelig melding
Hi! Trygve,
wrote:
> Greetings!
> Trygve
Opprinnelig melding
> Hi All,
and
> data1 var byte
> input 7
Subject and
