SV: [basicstamps] BS2P problem
Greetings!
What kind of sensor are you using?
Trygve
Opprinnelig melding
Fra: wanyia [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rUgVB0FVMPWpHF0lyccLJtBnWn4NPXoetbttoXhpxNG5hDBp5e0g6Bn7IooF9_mbD2WmnWTDXMS_]wanyia@y...[/url
Sendt: 23. mai 2002 15:26
Til: basicstamps@yahoogroups.com
Emne: [noparse][[/noparse]basicstamps] BS2P problem
Hi All,
Now i am doing my basic stamp project using BS2p to recieve and
read the data from the sensor. I am really new for programming and
also basic stamp. As well, i met the problem for recieving and
reading the data from sensor. here is my code:
data1 var byte
input 7
serin 7, 18447, [noparse][[/noparse]dec data1]
How can i do if i wanna read the data from the sensor as well?
Trygve
Opprinnelig melding
Hi All,
data1 var byte
input 7
I am using capacitive level sensor. With this sensor, it can with
pc via serial port. then i connected it with bs2p with null modem
connection. Thank you very much for taking your time[noparse]:)[/noparse]
--- In basicstamps@y..., Trygve Henriksen <trygve.henriksen@v...>
wrote:
> Greetings!
> Trygve
Opprinnelig melding
> Fra: wanyia [noparse][[/noparse]mailto:wanyia@y...]
> Til: basicstamps@y...
> Hi All,
and
> data1 var byte
> input 7
> basicstamps-unsubscribe@y...
Subject and
data books.
I can't help you further, I'm not an expert in capacitive sensors.
Maybe you can use the instruction RCTIME, but I'm really not sure.
>From: "wanyia" <wanyia@y...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: SV: [noparse][[/noparse]basicstamps] BS2P problem
>Date: Thu, 23 May 2002 13:38:18 -0000
>Hi! Trygve,
>wrote:
> > Greetings!
> > Trygve
Opprinnelig melding
> > Hi All,
>and
> > data1 var byte
> > input 7
>Subject and
_________________________________________________________________
Verzend en ontvang Hotmail via je mobieltje: http://mobile.msn.com
