Javelin Stamp -- StampPlot Object
Hi all,
For any interested parties I have developed a StampPlot object for the Javelin,
the pending Java-based controller from Parallax (with a little help from
Parallax and others).
Some of the features of the StampPlot object:
Plot configuration is performed from the Javelin.
StampPlot1.init();
10 channels of analog plotting
StampPlot1.plotValues(int val1, int val2, int val3);
StampPlot1.plot(int channel, int value);
8 Channels of digital plotting
StampPlot1.plotDigital(true/false);
StampPlot1.plotDigital(int byte value, int number of bits);
Logging of data and naming of log file
StampPlot1.logData("Javelin Log.txt");
StampPlot1.logData(true);
Write and read the 'green text' data value box
StampPlot1.dataVal(string);
string = StampPlot1.dataVal();
4 gauges which can be easily set, changed, and enabled for alarming.
StampPlot1.setGauge(int number, int value);
3 Analog sliders which can be easily read.
int = StampPlot1.readSlider(int number);
8 LED indicators
StampPlot1.setLED(int number, true/false);
StampPlot1.setLED(5,CPU.read(CPU.pin5);
8 Switch which may be read:
bool = StampPlot1.readSW(int number);
CPU.writePin(CPU.pin8,StampPlot1.readSW(4));
Send raw StampPlot instructions
StampPlot1.raw("instruction string");
For example, to read a StampPlot object switch and energize an out on the
Javelin:
// Sets Javelin P5 = StampPlot switch 5
CPU.writePin(CPU.pin5,StampPlot1.readSW(5));
Writing code in a structured, object oriented language is such a nice change [noparse]:)[/noparse]
The Object Class, example test file, and class descritions are available at:
http://www.selmaware.com/stampPlot/samples/javelin/javelin_stampplot1_class.htm
Hope it whets your appetite for the Javelin [noparse]:)[/noparse]
-Martin Hebel
SelmaWare Solutions
http://www.selmaware.com/stampplot
and
Southern Illinois University, Electronic Systems Technologies
http://www.siu.edu/~imsasa/est
StampPlot1.init();
8 LED indicators
Javelin:
-Martin Hebel
SelmaWare Solutions
and
