several bs to one out?
i use the bs2x to messure the rctime .
in a projekt i need more rctime-inputs than the stamp provides.
i want to connect several stamps to have more pins.
all my data i sent via the pin 16 of one stamp to the midi input of my
midiinterface...
ist it possible to connect the second ,third bstamp to the same
midiport.
Is there a solution
is it possible?
thank you.
***niki
midiinterface...
midiport.
Is there a solution
is it possible?
thank you.
***niki
can command it over two wires to give you 16 extra I/O. You can add more
PAKs using the same wires plus 1 wire/device. Or, you could switch to a
BS/2P-40.
Just a few ideas. PAK-IV is at http://www.al-williams.com/awce/pak3.htm
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: sonogames [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=22-G0ZHjY5BKXmXbuEp1d8MiOPSz1Z-gz7RWPtL0JjgQdnuDNneyDRG1Mol1wU_ZR5zvRwPV6v1U]luxus@b...[/url
> Sent: Sunday, May 19, 2002 11:47 AM
> Subject: [noparse][[/noparse]basicstamps] several bs to one out?
> provides. i want to connect several stamps to have more pins.
> input of my
> midiinterface...
> midiport.
> Is there a solution
> is it possible?
> thank you.
> ***niki
> from the same email address that you subscribed. Text in the
