code help
My assembler hangs at the 'GETABS' line in the following example code.
Any suggestions on how I might best reprogram that line?
MANT1 RMB 2
EXP1 RMB 1
MANT2 RMB 2
EXP2 RMB 1
GETABS BCLR MANT2,$80
LDD MANT1
ANDA #$7F
RTS
What about:
GETABS LDD MANT2
andd #$8000
std mant2
LDD MANT1
ANDA #$7F
RTS
thanks,
Ronnie
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
MANT1 RMB 2
EXP1 RMB 1
MANT2 RMB 2
EXP2 RMB 1
LDD MANT1
ANDA #$7F
RTS
What about:
GETABS LDD MANT2
andd #$8000
std mant2
LDD MANT1
ANDA #$7F
RTS
thanks,
Ronnie
or variable within the stamp program. For the keypad I am using
the lookup function for each of the 4 sets of keys and this works
good. What I am wanting to be able to do is shift the digits of a
variable and set the next digit in place. Example say you want to
type and set the variable to 1500 press key 1 and then press 5 the
one shifts one place to left and 5 inserts itself. Here is the code I
am using I am sure their is room for improvement. I am using a
74hc595 and 74hc165 to set the inputs for the keypad. Here is the
code I am using can anyone help me around this.
Mark W.
'{$STAMP BS2sx}
dis1 var byte
keyp var byte
result var byte
counter1 var word
keyp1 con 250
reset
dis1=%11101111
start
dis1=dis1>>%1
if dis1=%00000111 then reset
shiftout 10,12,1,[noparse][[/noparse]dis1]
high 11
pause 5
low 11
if dis1=14 then row1
if dis1=29 then row2
if dis1=59 then row3
if dis1=119 then row4
goto start
row1
high 15
shiftin 13,14,3,[noparse][[/noparse]result]
low 15
result=result-%10000000
result=result>>3
if result=15 then start
lookup result,[noparse][[/noparse]0,0,0,0,0,0,0,1,0,0,0,2,0,3,99],keyp
pause keyp1
debug dec keyp
goto start
row2
high 15
low 15
result=result>>3
lookup result,[noparse][[/noparse]0,0,0,0,0,0,0,4,0,0,0,5,0,6,66],keyp
pause keyp1
debug dec keyp
goto start
row3
high 15
low 15
result=result>>3
lookup result,[noparse][[/noparse]0,0,0,0,0,0,0,7,0,0,0,8,0,9,22],keyp
pause keyp1
debug dec keyp
goto start
row4
high 15
low 15
result=result>>3
lookup
result,[noparse][[/noparse]0,0,0,0,0,0,0,300,0,0,0,0,0,999,1000],keyp
pause keyp1
debug dec keyp
goto start
Mark Waddell
Stueken LLC
137 Southchase Blvd.
Foutain Inn SC 29644
Phone 864-862-0612 ext. 19
Fax 864-862-0614
Email: mwaddell@s...
with decimal numbers is a matter of multiplying your current result by ten,
then adding the new digit. If you have "back" key on your keyboard, you can
employ it by dividing your current value by 10.
-- Jon Williams
-- Parallax
In a message dated 5/23/2003 9:31:58 AM Central Standard Time,
mwaddell@s... writes:
> I am using a 4X4 keypad and I am needing a way to set a counter
> Thanks
> Mark W.
