Magstripe interface - multiple serial datastreams
Hello everyone,
I'm trying to interface with a magnetic card reader that would require me to
read
three seperate inputs at the same time. I'm fairly new with the stamp, and I'm
learning on a Stamp 2sx.
There are seperate clock and data lines for tracks 1 2 and 3 for a total of six
lines. They are clocked seperately because there are different data densities on
each stripe, and the data rate is dependent on the rate at which the user is
inserting or withdrawing the card.
I know it is trivial to read the data from one particular stripe (data/clock
pair) at a
time with SHIFTIN, but the problem is the data is coming from three sources at
once at different clock rates. Am I up a creek without a paddle? Is there some
trivially easy way to do this short of having the user swipe the card three
times?
Thanks in advance for any help,
John Laur
read
pair) at a
times?
John Laur
register for each line they would fill up and you would shift
them back out to your sx one at a time.
Sent: May 16, 2002 12:07 PM
Subject: [noparse][[/noparse]basicstamps] Magstripe interface - multiple serial
datastreams
Hello everyone,
require me to read
stamp, and I'm
a total of six
data densities on
the user is
(data/clock pair) at a
three sources at
Is there some
card three times?
John Laur
from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
ISO7811 standard provides the following:
Track 1: 210 bits/in for 79 6 bit read-only characters
Track 2: 75 bits/in for 40 4 bit characters
Track 3: 210 bits/in for 107 4 bit characters
Inhumanly fast (50 in/s) swiping should yield a data rate of no more
than 10,000bps or so: the problem is that the stamp hasn't the
interrupts,
though I think the 2sx may be fast enough to simply "poll" the clock
lines in
a tight loop while stacking the bits up in some variables. Is this
totally
infeasable? Programming a pic to cache the read and spit it out
serially when
complete probably wouldn't be that hard, but I don't have the
equipment...
Can you elaborate a little more on the shift register solution -
perhaps you have
seen a project using something like this? I am still pretty green
when it comes
to microcontrollers.
John
--- In basicstamps@y..., "Larry Gaminde" <lgaminde@t...> wrote:
> Not knowing how much data is on each line, I would use a shift
> From: "gorkish" <gorkish@h...>
> To: <basicstamps@y...>
> datastreams
> Hello everyone,
> require me to read
> stamp, and I'm
> a total of six
> data densities on
> the user is
> three sources at
> Is there some
> card three times?
> John Laur
> basicstamps-unsubscribe@y...
