hacking into motion detector
Hey guys,
Anyone hacked into a motion detector and used this signal with basic
stamp? Of course, the output current on a high has to be around 20
mA. I'm wanting to use the detector's signal to be recognized by
stamp to control movement on a servo. Any ideas? Thanks.
Jon
Jon
You should be able to find lots of info on the web. Try this site out for a
start
http://www.jesseshuntingpage.com/homebrew-cams.html
Steve
At 06:26 PM 5/14/02 +0000, you wrote:
>Hey guys,
>Jon
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
What I did was remove the relay for output and install a resistor
across the coil terminal ( I used a pot first this allowed me to
vary the resistance while checking the current ) there is a point
at which the voltage on the resistor does not change from high to
low you back it off a bit and this is your lowest current drain.
I also removed the voltage regulator and used 4 c cells @ 6vdc
and this helped with current drain also.
larry
Sent: May 14, 2002 1:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] hacking into motion detector
Jon,
out for a
start
Steve
>Hey guys,
basic
20
by
>Jon
Subject and
Subject and Body of the message will be ignored.
