Mosfet driving questions
Greetings!
I have a question concerning mosfet driving and I was hoping someone might be
able to help me out. I have an oscillator outputting a 140 khz square wave.
(note this is a square wave that swings from both positive and negative
voltages,(+8 to -8 volts and is not a clock pulse.) and I was wondering if
anyone knew any slick ways of interfacing this to an IRFIZ34G N channel HEXFET
MOSFET (stats below) I tried tying the oscillator directly to the gate but when
I measure the gate the wave seems to distort. The wave actually looks like a
sine wave when I do this... I don't understand why this is happening because i
thought the gates on mosfets had a very high input impedance so they would be
easy to drive... I would further like to note that I am aware N channel mosfets
only conduct when the gate is made positive so the negative portion of my square
wave wouldn't do anything.
Any help would be useful!
Thanks!
Randy Knutson
Minnesota State University, Mankato
IRFIZ34G
N CHANNEL HEXFET
VDSS 60V
RDSS .050 OHM
ID 20A
Do You Yahoo!?
Yahoo! Shopping - Mother's Day is May 12th!
Thanks!
Randy Knutson
IRFIZ34G
N CHANNEL HEXFET
VDSS 60V
RDSS .050 OHM
ID 20A
Do You Yahoo!?
>Greetings!
>be able to help me out. I have an oscillator outputting a 140 khz square
>wave. (note this is a square wave that swings from both positive and
>negative voltages,(+8 to -8 volts and is not a clock pulse.) and I was
>wondering if anyone knew any slick ways of interfacing this to an IRFIZ34G
>N channel HEXFET MOSFET (stats below) I tried tying the oscillator
>directly to the gate but when I measure the gate the wave seems to
>distort. The wave actually looks like a sine wave when I do this... I
>don't understand why this is happening because i thought the gates on
>mosfets had a very high input impedance so they would be easy to drive...
The gate lead on MOSFETs has a LOT of capacitance - anywhere from 3000 to
10000 pF, depending upon which FET you are using.
The easiest way is to use an off the shelf gate driver chip - IR makes one,
as does TI and many others.
I'd suggest a simple complementary emitter follower pair but your positive
pulse is a little low for voltage - the minimum gate voltage for that
family of FET is 10V and 12 - 15V is better. You]ve only got 8V to begin
with and you'd lose another 0.7 - 0.9V in the emitter follower.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
tying that amount of capacitance to ground from your oscillator and see
if the resultant wave form looks familiar.
HTH,
Leroy
Randy Knutson wrote:
> Greetings!
> Thanks!
> Randy Knutson
> IRFIZ34G
> N CHANNEL HEXFET
> VDSS 60V
> RDSS .050 OHM
> ID 20A
> Do You Yahoo!?
level switching (<2volts=off , >3=on) then if you really need that much
current you could let the 2n7000 switch 12v to the other one. not sure how
much output current you have available to overcome the gate capacitance at
that freq. but the 2n7000's have a fairly low gate capacitance, where
heavier ones have more.
KF4HAZ - Lonnie
> Greetings!
wondering if anyone knew any slick ways of interfacing this to an IRFIZ34G N
channel HEXFET MOSFET (stats below) I tried tying the oscillator directly to
the gate but when I measure the gate the wave seems to distort. The wave
actually looks like a sine wave when I do this... I don't understand why
this is happening because i thought the gates on mosfets had a very high
input impedance so they would be easy to drive... I would further like to
note that I am aware N channel mosfets only conduct when the gate is made
positive so the negative portion of my square wave wouldn't do anything.
> Thanks!
> Randy Knutson
> IRFIZ34G
> N CHANNEL HEXFET
> VDSS 60V
> RDSS .050 OHM
> ID 20A
