muscle wires
I have some muscle wires, which can be made to expand and contract by running
small voltages through them to heat them up to about 70 deg C. The
transition happens pretty rapidly over a small temperature range, so it's
kind of jerky. I am thinking that if I could measure the temperature of the
wire and adjust the voltage being applied, I might be able to control how
fast the wire changes shape.
Can you get a temperature probe that can measure the temperature of a wire?
Has anyone else used stamps with muscle wires?
thanks
thanks
attach these to the wires with epoxy and measure the resistance which
corresponds to the actual temperature of the device.
Jim
From: eclecticrr@A... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YGFelM4Mp8lvk382MPXfOcaeRMlL58-UtoV6RCrDeBFrisYoXCszdJaPI94TbTOLgf66BvdlLwwbiinn]eclecticrr@A...[/url
Sent: Friday, May 10, 2002 3:49 AM
Subject: [noparse][[/noparse]basicstamps] muscle wires
running
thanks
regulator can be converted by wiring the input pin to your voltage source
about +6vdc to +15vdc, then wiring a resistor(R) in series with the output
pin and the muscle wire then wire the other side of your muscle wire to a
NPN transistor (to be switched by the stamp), then wire the adj. pin between
the resistor(R) and the muscle wire. The current out is equal to 1.25
divided by (R) where R is the resistance in ohms. Set the current according
to the wire spec. By keeping the current constant the wire will not burn up
by mistake and it will move with less jerk because as the wire heats up it
changes it's internal resistance and try's to pull more current but the
constant current device will automatically adj. the voltage to keep the
current constant. If you need a schematic of this contact me by e-mailing to
skip.webb@h... good luck with your experiment. Skip
From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vjHvqRIqRuiiWQmj2lMqmNNNvPfaDOhuZKDkjiVoKbv4nU7032F8zth_VfKUvl42AslZSvs]jjf@p...[/url
Sent: Friday, May 10, 2002 7:21 AM
Subject: RE: [noparse][[/noparse]basicstamps] muscle wires
You can buy a device called a thermocouple from places like digi-key. Just
Jim
From: eclecticrr@A... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pIxneSciVHAIPwuqZkTWgueq_yCIJMV6ItyJCao1IEnCd0rxmxTy8JWgKXzIzwBdqlPKfRqvXwHI]eclecticrr@A...[/url
running
thanks
Don
Sent: Friday, May 10, 2002 5:35 AM
> Are you using a constant current device? If not, you should. A 317t
voltage
between
according
up
to
> From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-HEKVgqgSXiIGJEA-xfdidn97Je4nOCz7uYu80EVUajf1TjdwBAVbUL-lmLcxiwPDX1aFw1m]jjf@p...[/url
Just
> Jim
> From: eclecticrr@A... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=C5GdqQhbmuK0-lfcQL2ssDgxKJQ0nJMTibkOF8JjUOBe2VmNxt8KISxlm1_cL7azUJLwD3cTb5SB1lQ]eclecticrr@A...[/url
> running
the
wire?
> thanks
From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Jmg_9rwbyG_vYM3yGaktCnFxEU-nen80RgYyTdH7jhWnuad2qVmXNknuBxh6a3RrIa9Y5HxOASLoZsHWOJYX2_fXOOCc]renegade.engineer@v...[/url
Sent: Friday, May 10, 2002 12:30 PM
Subject: Re: [noparse][[/noparse]basicstamps] muscle wires
Thanks Skip! Nicely drawn schematic!
Don
voltage
between
according
up
to
> From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Mlo-x5WfqBwYKkYyAdWpEu1nIE3lkmr7VOFsnOx1P5rtupyRS3VA-tmMDBWiZjGT36kzVWjwfSE5HA]jjf@p...[/url
Just
> Jim
> From: eclecticrr@A... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=H7aeoMBuODc68o14A63-UZmEM4vW7tCfE8t4Zoq7NIsZSs6WP-8A7_qptR9ZoJ9VNHeLRZgWU5w]eclecticrr@A...[/url
> running
the
wire?
> thanks
sensor" category and they appear to cost about $95 each. That's more than I
want to pay unless I'm readying something wrong. Do you have any less
expensive suggestions?
thanks
In a message dated 05/10/2002 4:34:17 AM Pacific Daylight Time,
jjf@p... writes:
<< You can buy a device called a thermocouple from places like digi-key. Just
Jim >>
