basics of of bs2>bs2 serial communication
hi everybody.
I'm trying to set up a super-basic serial communication between two bs2.
I've connected pin 11 of the first stamp to pin 11 of the second stamp
the first stamp is running to following code >
here:
serout 11\11,16468,[noparse][[/noparse]65]
pause 100
goto here
the second stamp is running to following code >
my_var var byte
here:
serin 11\11,16468,[noparse][[/noparse]my_var]
debug my_var,cr
pause 100
goto here
I'm not getting any output in the debug window from my second stamp (which
is connected tot he pc via the serial cable)
I'm sure I'm doing something foolishly wrong, but I can't figure it out.
Any hints??
thanks!
here:
pause 100
goto here
my_var var byte
here:
debug my_var,cr
pause 100
goto here
Any hints??
thanks!
don't use the \Fpin option in either code. That is for synchronous comm
only. Change your serout to serout 11,16468,... and the serin likewise.
Don
Sent: Tuesday, May 07, 2002 9:45 PM
Subject: [noparse][[/noparse]basicstamps] basics of of bs2>bs2 serial communication
> hi everybody.
> here:
> pause 100
> goto here
> my_var var byte
> here:
> debug my_var,cr
> pause 100
> goto here
> Any hints??
> thanks!
You asked my question! you are my heroe!!!
>From: "Don" <renegade.engineer@v...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] basics of of bs2>bs2 serial communication
>Date: Tue, 7 May 2002 22:46:09 -0700
> You need to connect the ground pins of the two stamps as well. And
>Don
>From: "raoul vaneigem" <raoul@c...>
> > hi everybody.
> > here:
> > pause 100
> > goto here
> > my_var var byte
> > here:
> > debug my_var,cr
> > pause 100
> > goto here
>(which
> > Any hints??
> > thanks!
>and
_________________________________________________________________
MSN Photos es la manera m
Don
Sent: Wednesday, May 08, 2002 7:23 AM
> Don,
> >Don
> > > hi everybody.
bs2.
> > > here:
> > > pause 100
> > > goto here
> > > my_var var byte
> > > here:
> > > debug my_var,cr
> > > pause 100
> > > goto here
> >(which
out.
> > > Any hints??
> > > thanks!
> >and
