Coding question
Can someone translate into plain english what this code snippit is doing, in
particular the "initbits" line. The sub is setting the mode and channel number
in a 8 channel A/D. I know the sub is going through all the channels, my
question is "what" is it doing to initbits??
Thanks.
(P.S. It owrks fine, I just don't understand the line)
Mike B.
for Channel = 0 to 7
InitBits = %11000 | ((Channel & %001) << 2) | ((Channel & %110) >> 1)
gosub GetADCResult
debug "Channel ",DEC Channel, ": ",DEC ADCResult,CR
Thanks.
Mike B.
gosub GetADCResult
11ACB
Where the channel number (in binary) looks like CBA.
So if CBA = 101 then Initbits=11110
If CBA=011 then Initbits = 11101
The & %001 strips the least significant bit
The & %110 isolates the two bits to the left
The <<2 shifts the first bit 2 places over to the left
The >>1 shifts the other two bits one place to the right
The | (or) operator glues it all together.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: Mike Blier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a4TTET3_dTo0wJ1EDRfNvUsI_C5GtFkK9lzCmIAHHdW4cyiJvPP1jai0YEf6-RY1-fr7r0dVOTOr]w6ffc@p...[/url
> Sent: Tuesday, May 07, 2002 9:31 PM
> To: Basicstamps@Yahoogroups.Com
> Subject: [noparse][[/noparse]basicstamps] Coding question
> snippit is doing, in particular the "initbits" line. The sub
> is setting the mode and channel number in a 8 channel A/D. I
> know the sub is going through all the channels, my question
> Thanks.
> Mike B.
> gosub GetADCResult
> from the same email address that you subscribed. Text in the
cycle through all the 8 combos.
Looking forward to getting your RS232 adaptor I ordered the other day..
MIke B.
Sent: Tuesday, May 07, 2002 7:57 PM
Subject: RE: [noparse][[/noparse]basicstamps] Coding question
> This forms a bit pattern that looks like this:
> 11ACB
> Al Williams
> AWC
> > From: Mike Blier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KzanpCiydEceCRwZxl_dFz-9pnx64h4cGcZhllyBBOwXe83BM6akUWq6CFR3rsCjbFS-lBIFgJod-Ic]w6ffc@p...[/url
> > Thanks.
> > Mike B.
> > gosub GetADCResult
converter is: 000, 100, 001, 101, 010, 110, 011, 111 for channels 0
to 7 respectively. The code will generate these bit patterns
(preceded by a binary 11) and step through all channels in ascending
sequence.
Regards, Marylou
_______________________________________
--- In basicstamps@y..., Mike Blier <w6ffc@p...> wrote:
> Ok thanks Al... That's clear as mud.. <g> Seems like a round
about way to
day..
> MIke B.
> From: "Al Williams" <alw@a...>
> To: <basicstamps@y...>
> > 11ACB
> > Al Williams
> > AWC
> > > From: Mike Blier [noparse][[/noparse]mailto:w6ffc@p...]
> > > To: Basicstamps@Y...
> > > Thanks.
> > > Mike B.
>> 1)
> > > gosub GetADCResult
> > > basicstamps-unsubscribe@y...
Subject and
