120 VAC coils
So I guess this means you are NOT interested in any kind of bet that
say's a 24 VAC coil WILL NOT function longer that 24 hours on 24 VDC and
that in fact it will burn up from over current and over load.. Is that
correct, Mr. Higgins? Any other opinions on this matter? I know that
AC coils are not meant to work on DC, but that is not the question.
Question is will they or not?? Come on be brave let's hear about your
technical expertise. Any real opinions or just a bunch of wimps?
Leroy
I might be willing to make a small wager on whether an AC valve,
solenoid, or other type of coil could be run on an equivalent value of
DC, if there are any takers, I could use some extra money. :-))))
Leroy, I've seen 120 VAC coils burned up by 24 VDC. It all depends on
the DC resistance of the coil. I'm sure you can find a solenoid that
works fine if you search hard enough, but in general, without knowing
the
specifications of the solenoid beforehand, recommending use of DC to
power an AC solenoid, voltage remaining the same, is a very bad idea.
As to any bet, Leroy, just give it a few hours to a day and maybe some
of the other guys who have been there will straighten you out - and it
won't cost you a dime.
Leroy
the
If I may jump in here: the 24 Vac solenoids I usually use here at Trinity
Electronics will, without question, eventually disappear in a cloud of
smoke if left powered continuously at 24 Vdc.
For example, one solenoid I use in my desoldering stations has 2 ratings on
the coil: 120 Vac 60 Hz *and* 32 Vdc. I run them at 32 Vdc.
We control a lot of Asco solenoids with our oven control systems and I
spent many hours abusing the solenoids to see how they react to various
over voltage and under voltage conditions. They don't smell nice if you
hit them with 24 Vdc and leave them for a while.
I'm sure there must be solenoids out there that will work with the same AC
or DC voltage but not the ones I use.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
The physic of this means that 24VDC DOES NOT EQUAL 24 volts RMS. All
the text books I have read seem to make this analogy. Maybe they are
wrong. Thanks for your input..
Leroy
> dwayne
>>the
Leroy, I imagine my industrial experience in this area will only be
apocryphal evidence as far as you are concerned so I'll not waste my time
citing real world incidents of exactly this problem, as well as burning out
the coils of AC solenoids simply because they were removed from their
armatures and left off for a period of time on the order of only a few
hours while activated. But I'm just sick enough of your nonsense to bet
you $5 on the following terms.
1. Wording of the bet to be "that it is, IN GENERAL, a bad idea to operate
a solenoid actuator coil designed for 24 VAC continuous service on 24 VDC
continuously because it is likely to overheat and burn up as a result." No
added conditions, modifications or reservations to the quoted words allowed.
2. We run no tests on any real relays because I can find one to support my
assertion and I will stipulate that you can find one to support your
assertion and that we'd have to test or perform calculations on too many
different relays to demonstrate the truth (or lack thereof) of the GENERAL
assertion in #1 above.
3. Therefore, if you agree to the bet, it will be turned over to any one
of Al Williams, Tracy Allen, Beau Schwabe, Ben Trueblood, Ken Gracey, or
Peter Anderson, for final decision, assuming for a second any of these
gentlemen care to get into the middle of this pissing contest. (I have
deliberately left out Dwayne Reid because he has already weighed in with
the opinion that you are wrong. Any other omissions are not meant to
slight anyone.)
4. If none of these "judges" volunteers for the task within a time frame
that indicates they ever will, say 48 hours from the date of this posting,
the bet is off and we both shut the hell up about it. (There's incentive
not to volunteer if ever there was any, but I'm counting on a desire to
support the best advice to prevail. After all, there's areal guy out there
who may go either way on it.)
5. Payment to be made by mail in the form of a $5 bill, US currency, and
admission of defeat is to be made to the mailing list by the one losing the
bet in the form of:
"Dear (winner's name here),
You da MAN!
Love, (loser's name here)"
What say, Leroy? (Al, Tracy, Beau, Ben, Ken or Peter?)
Jim H
rated current may well overheat it. How much current will flow in a coil?
I = V/Z where Z is the coil impedance. Operating from AC, the impedance, Z,
is sqrt[noparse][[/noparse]R^2+(2*Pi*f*L)^2]. sqrt is square root. R is coil resistance; Pi
is 2.14159; f is frequency, like 60 Hz. L is coil inductance. In plain
english, the AC impedance is determined by resistance and inductance. When
operating the same coil on DC, total impedance is simply R, so more current
will flow in the DC case. The relay or coil will certainly operate on DC
because of the higher current, since magnetic force is determined by
ampere-turns of the coil, but heating will also increase. I have
successfully operated AC relays on DC by applying reduced DC voltage. If
you can determine the rated coil current, all you have to do is measure the
coil resistance and apply a DC voltage that will yield that current.
Long-winded, but hopefully useful,
Ray McArthur
Sent: Monday, May 06, 2002 10:09 PM
Subject: Re: [noparse][[/noparse]basicstamps] 120 VAC coils
> The heating of a coil depends on the coil current. Operating a coil above
Z,
Pi
When
current
the
> Ray McArthur
explained I made a stupid mistake. However, I have learned a lot from the
discussion. I have seen other arguments on this and other boards get down
right nasty. I congratulate all that responded for keeping every thing on a
fairly high level. Things were limited to pointing out typos, others
opinions and basic A.C theory. Though I have significant industry experience
I am always interested in someone else's actual experience.
Sorry I got this started - but I did benefit from the discussion.
Richard
To: <basicstamps@yahoogroups.com>; <dwayner@p...>
Sent: Monday, May 06, 2002 9:08 PM
> Dear Dwayne,
> Leroy
and
Trinity
on
AC
> > dwayne
From my teaching experience I would say that the most learning occurs in
this type of situation. Ever coin has two sides and every question has
more than one answer. If you don't seek out all the answers, you have
just a dim light of reality. My reason for being on this board is to
learn a little and maybe teach a little. I am glad you raised the
question, it's really good for the group. Some may get a little
nervous, but they usually can't understand that they may not know the
whole truth.
I certainly don't know everything and I would be the first to admit
that, Just because I have taught Electro-mechanical engineering for 15+
years doesn't mean that I taught everything.
Thanks again for your question.
HTH,
Leroy
> I started the this mess by incorrectly stating power dissipation. I already
> Richard
> From: "Leroy Hall" <leroy@f...>
> > Dear Dwayne,
> > Leroy
> and
> Trinity
> on
> AC
> > > dwayne
Ray McArthur
Sent: Tuesday, May 07, 2002 9:33 AM
> Pi = 3.14159
> From: "Ray McArthur" <rjmca@u...>
I was wrong here send me your address:
leroy
and
the bet in the form of:
"Dear (Jim H),
You da MAN!
Love, (Leroy)"
Jim H
>Jim,
>leroy
>and
>"Dear (Jim H),
> You da MAN!
>Love, (Leroy)"
Beau Schwabe Mask Designer IV - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
>Jim,
Leroy,
If you don't mind just forgetting about it, I am glad to just forget it also.
In the alternative, I've sent my address privately.
Jim H
