The BS1 and Windows XP — Parallax Forums
edited 2002-05-16 22:50 in General Discussion
I have tried to program my BS1 on computers with windows XP and it
won't work. It can be programed on my old WIN98 comp, but for some
reason it keeps saying "hardware not found" on XP. I have tried many
good batteries, and my BS1 works fine. Anyone know the problem?
    edited 2002-05-07 00:29
    Yeah, XP stinks when it comes to dealing with hardware!!
    many
    edited 2002-05-07 00:58
    Works fine on my WinXP laptop. I suggest you check the settings onf
    your com port.
    many
    edited 2002-05-07 21:18
    I am not very good at computer stuff, so I don't know where to go to
    check my com ports. Where do I go and what should they look like?
    (It's for the BS1) Also, I don't have a 9-pin connector on my cp, and
    I was thinking of buying a 9-pin to USB cord. Could I use my BS2 with
    that? Please get back with me on this because I am right in the
    middle of a robotics project at my Technical School and I'm in a
    hurry! Thanks for the info!
    onf
    > your com port.
    it
    some
    > many
    edited 2002-05-07 22:15
    I use a Keyspan high speed USB serial adapter (USA19QW) and it works great.
    Cost about $50.00 to $60.00, hope
    this helps.
    Have Fun !!
    Dale Fleischmann
    > onf
    > > your com port.
    > it
    > some
    > > many
    edited 2002-05-08 15:54
    >>>XP and it won't work. It can be programed on my old WIN98
    >>>comp, but for some reason it keeps saying "hardware not found"
    >>>on XP. I have tried many good batteries, and my BS1 works fine.
    >>on your com port.
    He says he has a BS1 - it needs a parallel port.
    I'm confused. Do you need to program a BS1 or a BS2? Or do you have
    both? Big difference.
    The BS1 connects to your computer's parallel port and programs using a DOS
    program. If it's even possible to access the parallel port on a WinXP
    system using DOS software, I suggest it will be so much trouble to make it
    work reliably (if at all) that your best bet is to use another computer
    running just plain DOS if you really have to program a BS1. It may run on
    a Win9x system, but forget WinXP. WinXP doesn't allow access to hardware
    by DOS programs. If there are any workarounds I don't know them and you
    sound like you don't have time to burn playing with them. Find a DOS
    machine if you have to program a BS1.
    The BS2 connects to one of your computer's serial ports and programs using
    DOS or Windows software. If you have a BS2, I strongly suggest you use the
    Windows programming software to avoid similar problems with accessing
    hardware ports under WinXP. Alternatively, use the DOS software and find a
    DOS machine.
    Software for programming either of these Stamps is available for free from
    the Downloads section of the Parallax website at
    http://www.parallaxinc.com. For the BS2, you really need the Windows
    version if you're going to run it on a Windows machine. As I mentioned
    above, there may be exceptions, but not under WinXP/2000 and not at the
    last minute. Plan on the time needed to download a 3.3 megabyte program.
    From here on I'm assuming you have a BS2.
    You don't make it clear whether or not you have a serial port on your
    computer; you just say you don't have a 9-pin port. On the assumption that
    you have a serial port, I assume it's a 25-pin port. If so, I suggest you
    get a 25-pin to 9-pin adapter (under $10 at Radio Shack) and use that port
    instead of adding the complication of making a USB-to-serial interface work
    for what you already describe as a last minute project. If you are having
    difficulty identifying what the ports are on the back of your machine, look
    for the serial port to be labeled COM1 or COM2, or maybe labeled something
    like "101010."
    I think this probably covers what you need to know to talk to whatever
    version of the Stamp you might have, and the most likely pitfalls you might
    face.
    Good luck!
    Jim H
    edited 2002-05-08 22:04
    I appreciate all of the help you guys have given me, and I understand
    it all, but allow me to be more specific on my computer. I have a
    parallel port that works with my BS1, but the CP doesn't recognize
    the hardware. I also have a BS2, but I only have a 15pin port for it
    and, of course, it won't work with my BS2. I do have two serial
    ports, but I'll need an adaptor. I have no other computers, so I MUST
    make this work somehow with my Basic Stamps (either one). I am no
    longer on a short schedule because of these problems. I need to know
    how to make one of these work. Please Help!
    edited 2002-05-08 22:41
    Ok, can we clarify a few things so everyone (especially me) will know
    what you are dealing with?
    You have a BS1, either on a Super Carrier board, or a Rev. D board, with
    a parallel cable to hook it to the PC.
    This doesn't work, correct so far?
    The BS1 can only be programmed in DOS, so it will never work in WinXP or
    Win2000. I run mine in a Win98 DOS Shell window.
    It works fine, and I can have the BS2 Windows based editor open at the
    same time, for cross checking communication variables, etc.
    Now, you have a BS2, I'm assuming on a BS2 carrier board or Super
    Carrier board, correct?
    I don't understand the reference to a 15 pin port. Is that on the PC?
    On what ever you are mounting the BS2?
    If it's on the PC, that sounds like a game port or some other peripheral
    port.
    You say you have two serial ports. I'm assuming you mean on your PC,
    correct?. By adapter, do you mean a DB-25 (25 pin) to DB-9 (9 pin) adapter?
    They are quite inexpensive. Or privately mail me your address and I'll mail
    you one. I have 2. Or you can get a female DB-25 head from your local
    Radio Shack and make a cable per the Basic Stamp manual. And remember, if
    the port on the back of the PC isn't male, it isn't a serial port.
    As for the Windows editor for the BS2 and higher, I got it working fine
    in Win2000. I was using a BS2 on Super Carrier board with the cable from
    Parallax, and the old version of the Windows editor. So it will work, I
    promise!
    I would like to help you if I can, but your emails have been confusing
    at times. Please clarify what you have and precisely what you are doing,
    and it's a good bet someone on here can help!
    It might also not be a bad idea to post a copy of the programs you are
    trying to run on the Group file page, if it's not too big to quickly trace.
    There might be something there. It's just a suggestion.
    Regards
    Don
    Sent: Wednesday, May 08, 2002 2:04 PM
    Subject: [noparse][[/noparse]basicstamps] The BS1 and Windows XP
    edited 2002-05-08 23:36
    Did you see the answer I gave you about 11:00 AM EDT? Do you have any
    specific questions about it?
    Jim H
    edited 2002-05-11 16:05
    Well Don, I have an 9-pin to parallel port adaptor now, and my BS2 is
    connected to the parallel port (COM3) on the back of my computer
    through my Super Carrier Board. However, when I try to use
    the "identify" button on the Windows BS2 program, it says that it
    detects the BS2, but for me to check the power supply. I have tried
    several batteries and they have all been good. So I still don't know
    what to do! When I try to program the BS1 with the super carrier
    board connected to the parallel port, it says "hardware not found".
    Those are my current problems. Please Help! What am I doing wrong?
    I would post up the program, but I can't get the programs to
    recognize the stamps, so they don't matter.
    will know
    board, with
    WinXP or
    at the
    Super
    the PC?
    peripheral
    > port.
    your PC,
    adapter?
    I'll mail
    local
    remember, if
    working fine
    cable from
    work, I
    > promise!
    confusing
    doing,
    you are
    quickly trace.
    > Regards
    > Don
    > From: "astro_fizzix" <astro_fizzix@y...>
    > To: <basicstamps@y...>
    understand
    it
    MUST
    know
    > > basicstamps-unsubscribe@y...
    Subject and
    edited 2002-05-11 21:08
    Not sure about the Super Carrier Board, but on the Stamp Activity Board I
    have you change some jumpers to switch from a BS1 to BS2. May want to check
    to see if your board requires this also.
    Ok, I think I'm getting the picture. You have some confusion over what
    is what on your computer. It sounds like you have at least 2 large (25-pin)
    connectors on the back. One will be female (all holes) and one will be male
    (all pins). The one with holes is your parallel port (where a non-USB
    printer would hook up). This one is known to the computer as LPT1. The
    connector with all pins will be a serial port, known to the computer as
    COM1, COM2, COM3, or COM4 depending on how it is set in your CMOS setup. If
    you have a 9-pin to 25 pin adapter, and the large end of the ADAPTER is all
    female, then you are connecting to the male serial port, not parallel. The
    BS1 can not be programmed through the serial port, regardless of which
    carrier board it is on.
    Don
    Sent: Saturday, May 11, 2002 8:05 AM
    Subject: [noparse][[/noparse]basicstamps] Re: The BS1 and Windows XP
    > will know
    > board, with
    > WinXP or
    > at the
    > Super
    > the PC?
    > peripheral
    > > port.
    > your PC,
    > adapter?
    > I'll mail
    > local
    > remember, if
    > working fine
    > cable from
    > work, I
    > > promise!
    > confusing
    > doing,
    > you are
    > quickly trace.
    > > Regards
    > > Don
    > understand
    > it
    > MUST
    > know
    > Subject and
