Time calculations
Hi group.
My R/C submarine and home built control unit both have Dallas real time
clocks in them. I have a need to look at the time and determine if a given
amout of time has passed. Doing time math is a pain and I wondered if someone
has "walked the mile" and come up with a routine to subtract time 2 from time
1??
Mike B.
(This sounds like a job for Al Williams)
1??
Mike B.
sprinkler controllers, we always dealt in minutes so time was represented by
a value from 0 (midnight) to 1439 (11:59 PM). This makes doing the math
pretty easy. It wouldn't be horribly difficult to deal with seconds
separately.
Here some easy math:
rawTimeVal = (hours * 60) + minutes
hours = rawTimeVal / 60
minutes = rawTimeVal // 60
-- Jon Williams
-- Parallax
In a message dated 5/5/02 6:47:40 PM Central Daylight Time, w6ffc@p...
writes:
> someone has "walked the mile" and come up with a routine to subtract time 2
> from time 1??
Thanks for the reply. Kind of expected to hear bad news. I'll have to
see if the RTC accumulates seconds and then does the conversion for you.
Don't know yet. Just getting started with the RTC portion of this
"SuperMax" add on board.
Here's what the hand held controller side has connected to the
SuperMax/Stamp 2 so far.
2 digit BCD thumbwheel via 3 wire serial 74LS165 for
function/display/play sound selection
QuadraVox voice recorder (four minute version)
5 watt, serially controlled UHF two way data radio for comms with the
submarine
6 two color LEDs via 3 wire serial to a 74HC595 to show submaring systems
status (looking for all green before diving, the "Green Board")
Serial LCD 4 X 20 display (Scott Edwards)
3 linear taper pot through 8 bit A/Ds for rudder, dive planes and speed
control
3 toggle switches to blow/vent the tanks
In the submarine there is a "Time Keeper 3.1" add on board for the
Stamp 2 with RTC and 128k EEPROM
serial 8 channel servo controller to control rudder/dive planes and
blow/vent valves. Speed is via an 80 amp R/C car speed control (looks like
a servo)
2 pressure transducers to measure the high pressure CO2 gas supply and the
low pressure distributed CO2
Several reed switches to a serial 74LS165 to indicate valve positions for
failure detection etc.
Serial two way UHF data radio
The controller portion is talking to the BCD, LCD and voice board today.
Tomorrow will get the POTS talking to the ADC's.
Love this Stamp stuff...
MIke B.
Sent: Sunday, May 05, 2002 4:53 PM
Subject: Re: [noparse][[/noparse]basicstamps] Time calculations
> Ease depends on the resolution you need, timewise. When I used to design
by
> separately.
> -- Jon Williams
> -- Parallax
w6ffc@p...
> writes:
time
given
time 2
> > from time 1??
read by nibbles (i.e HIGH NIB and LOW NIB), I did the math like this
timeX=(Seconds.HIGHNIB*10+Seconds.LOWNIB+
Minutes.HIGHNIB*600+Minutes.LOWNIB*60)
This gives me a time in total seconds. You should be able to compare
time1 and time2 as long as you don't exceed 1 hour. You could up the
time values to hours and minutes as long as you don't compare for
more than 24 hours apart.
HTH
Don
--- In basicstamps@y..., Mike Blier <w6ffc@p...> wrote:
> Hi group.
real time clocks in them. I have a need to look at the time and
determine if a given amout of time has passed. Doing time math is a
pain and I wondered if someone has "walked the mile" and come up with
a routine to subtract time 2 from time 1??
> Thanks
> Mike B.
hear from the boat in x number of seconds I need to panic and do something.
The problem as I saw it was if I heard from the boat at 58 seconds past the
minute and then again at 12 seconds past the going over 59 makes the math a
bit of a problem. I'm not so interested in the exact time as I am an
elapsed time.
Thanks, this message goes to the project folder....
Mike B.
Sent: Sunday, May 05, 2002 5:13 PM
Subject: [noparse][[/noparse]basicstamps] Re: Time calculations
> Knowing that the DS1302 RTC outputs byte values that need to be
> HTH
> Don
> > Hi group.
> > Thanks
> > Mike B.
midnight every time you heard from the boat? In this manner, your RTC
becomes and elapsed time timer.
-- Jon Williams
-- Parallax
In a message dated 5/5/02 8:03:06 PM Central Daylight Time, w6ffc@p...
writes:
> Ok, now were talking. I only need several second intervals. ie: if I don't
like this:
timeX=(Seconds.HIGHNIB*10+Seconds.LOWNIB)+
(Minutes.HIGHNIB*600+Minutes.LOWNIB*60)
Sorry, I forgot a couple parenthesis when I wrote before.
Good Luck
Don
if I don't
something.
past the
the math a
an
> elapsed time.
> Mike B.
> From: "mtlhead7" <renegade.engineer@v...>
> To: <basicstamps@y...>
this
compare
the
> > HTH
> > Don
> > > Hi group.
is a
with
> > > Thanks
> > > Mike B.
> > basicstamps-unsubscribe@y...
Subject and
((Minutes.HIGHNIB*600)+Minutes.LOWNIB*60))
I've been working on an array input problem all day and am getting
delirious.
I promise this one works!
Don
--- In basicstamps@y..., "mtlhead7" <renegade.engineer@v...> wrote:
> I looked back at my program and the formula should actually look
> like this:
> Good Luck
> Don
> if I don't
> something.
seconds
> past the
> the math a
am
> an
> > elapsed time.
> > Mike B.
be
> this
> compare
up
> the
for
> > > HTH
> > > Don
> > > > Hi group.
Dallas
> is a
up
> with
> > > > Thanks
> > > > Mike B.
> Subject and
Last time, I swear:
((Minutes.HIGHNIB*600)+(Minutes.LOWNIB*60))
Don
> Ok, my brain is fried. Try this one:
getting
> delirious.
> Don
look
> > like this:
> > Good Luck
> > Don
ie:
> > if I don't
do
> > something.
> seconds
> > past the
makes
> > the math a
> am
> > an
> > > elapsed time.
> > > Mike B.
to
> be
like
> > this
> > compare
could
> up
> > the
> for
> > > > HTH
> > > > Don
> > > > > Hi group.
> Dallas
and
math
> > is a
> up
> > with
> > > > > Thanks
> > > > > Mike B.
> > Subject and
Last time, I swear:
Don
getting
> delirious.
> Don
look
> > like this:
> > Good Luck
> > Don
ie:
> > if I don't
do
> > something.
> seconds
> > past the
makes
> > the math a
> am
> > an
> > > elapsed time.
> > > Mike B.
to
> be
like
> > this
> > compare
could
> up
> > the
> for
> > > > HTH
> > > > Don
> > > > > Hi group.
> Dallas
and
math
> > is a
> up
> > with
> > > > > Thanks
> > > > > Mike B.
> > Subject and
